Coloumb's Law Three Charges in a Line (units question)
  • Thread starter Thread starter thermocleanse
    Charges Law Line
thermocleanse
please c attachment.
thx.
μC ≡ 10-6 C. (You don't end up with an 'extra' μC on top.)
thx, doc al...i'm using 2 of "10^-6 C" on the top, set equal to 2 of "1C" on the bottom. that clears the units. thanks so much...
