Come One, Come All, and Cast Your Vote
  • Thread starter Thread starter bluestar
bluestar
Vote on which university has the correct normalized quantum harmonic oscillator equation!
Is it University #1
Georgia State University and the Hyperphysics site presented by the physics department.
http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/hosc2.html#c1
\psi_n \left( y \right) = \left( \frac {\alpha}{{\pi}} \right) ^ \frac{1}{{4}} \frac{1}{{\sqrt{2^nn!}}}H_n\left(y\right)e^{\frac{-y^2}{{2}}}
Where y = \sqrt{\alpha} x
and \alpha = \frac{m\omega}{{\hbar}}
Is it University #2
Oxford University with a paper from the Physical Chemistry department
http://physchem.ox.ac.uk/~hill/tutorials/qm2_tutorial/sho_series.pdf
\psi_v\left(y\right) = \frac{1}{{\sqrt{\pi}{{2^vv!}}}}H_v\left(y\right)e^{\frac{-y^2}{{2}}}
Where y = \sqrt{\frac{m\omega}{{\hbar}}}x
Or is it University #3
University of Glasgow with a paper from the Physics department
http://www.physics.gla.ac.uk/~dmiller/lectures/P409M_Miller_2008_section4.pdf
\psi_n \left( x \right) = \sqrt{\frac{\alpha}{{\sqrt{\pi}2^nn!}}}H_n\left(ax\right)e^\frac{-\alpha^2x^2}{{2}}
Where y = \alpha x
and \alpha = \sqrt{\frac{m\omega}{{\hbar}}}
The normalizing constant is different for each equation so they all can not be the same.
When you cast your vote it would be helpful to others if you would justify your selection.
Thanks for participating.
Check it yourself! Evaluate the normalization integral for each one and see which one(s) give you 1 for the result. :smile:
Of course, you'll have to pick a particular value of n (or \nu as the case may be) and use the corresponding particular Hermite polynomial.
Are you saying that I should evaluate each function for a specific n (or v) and the one that results in a value of 1 has the valid normalization constant? If so, I can do that.
Or
Are you suggesting evaluate the normalization integral. That I won’t be able to do for a couple of them do not provide that information. That is why I am asking for opinions.
I did some more checking around and found the answer to my question.
Shown below is the normalized harmonic equation from Michael Fowler at the University of Virginia. As can be seen the structure of the normalization constant is very similar to Georgia States Hyperphysics equation. After closer examination of the Hyperphysics equation I found the two equations to be equal. I also reexamined the Glasgow equation and found it was also equal to the other two. The confusion arose because the alphas were defined differently between Hyperphysics and Glasgow.
University of Virginia - Michael Fowler page
\psi_n \left( y \right) = \left( \frac {m\omega}{{\hbar\pi}} \right) ^ \frac{1}{{4}} \frac{1}{{\sqrt{2^nn!}}}H_n\left(y\right)e^{\frac{-y^2}{{2}}}
Where y = \frac{x}{{\alpha}}
and \alpha = \sqrt{\frac{\hbar}{{m\omega}}}
I am still puzzled as to why the prestigious Oxford equation does not match the others.
If you have any thoughts on the puzzle chime in.
I am also puzzled why 91 readers didn’t catch my initial error including JTBELL mentor. :-)
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
I asked a question related to a table levitating but I am going to try to be specific about my question after one of the forum mentors stated I should make my question more specific (although I'm still not sure why one couldn't have asked if a table levitating is possible according to physics). Specifically, I am interested in knowing how much justification we have for an extreme low probability thermal fluctuation that results in a "miraculous" event compared to, say, a dice roll. Does a...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
