Commutator problem with momentum operators
hellomister
Find the commutator <br /> \left[\hat{p_{x}},\hat{p_{y}}\right]<br />
\hat{p_{x}}=\frac{\hbar}{i}\frac{\partial}{\partial x}
\hat{p_{y}}=\frac{\hbar}{i}\frac{\partial}{\partial y}
[\hat{p}_{x}, \hat{p}_{y}]=\hat{p}_{x}\hat{p}_{y}-\hat{p}_{y}\hat{p}_{x}
=\frac{\hbar}{i}\frac{\partial}{\partial x}\frac{\hbar}{i}\frac{\partial}{\partial y}-\frac{\hbar}{i}\frac{\partial}{\partial y}\frac{\hbar}{i}\frac{\partial}{\partial x}
=(\frac{\hbar}{i})^2\frac{\partial^2}{\partial x\partial y}-(\frac{\hbar}{i})^2\frac{\partial^2}{\partial y\partial x}
Is this the correct commutator? I don't know what else I can do to further complete this. Any help is appreciated.
It's fine. But partial derivatives commute in the physics sense. Your two partial derivatives are equal.
Okay thanks for the response, i have a similar problem to that of the first that I put up, but I am very confused.
Problem
Show that [\hat{L}_{x},\hat{P}_{y}]=i\hbar\hat{P}_{z}.<br /> (Note: \hat{L}_{x}=y\hat{P}_{z}-z\hat{P}_{y})
Televant equations
\hat{p_{z}}=\frac{\hbar}{i}\frac{\partial}{\partial z}
Attempt
So i started out by just writing out the commutator in the general form:
(1) \hat{L}_{x}\hat{P}_{y}-\hat{P}_{y}\hat{L}_{x}
Then I slowly substituted some equations
(2) (y\hat{P}_{z}-z\hat{P}_{y})\frac{\hbar}{i}\frac{\partial}{\partial y}\psi-\frac{\hbar}{i}\frac{\partial}{\partial y}(y\hat{P}_{z}\psi-z\hat{P}_{y}\psi)
(3)(y\frac{\hbar}{i}\frac{\partial}{\partial z}-z\frac{\hbar}{i}\frac{\partial}{\partial y})\frac{\hbar}{i}\frac{\partial}{\partial y}\psi-\frac{\hbar}{i}\frac{\partial}{\partial y}(y\frac{\hbar}{i}\frac{\partial}{\partial z}\psi-z\frac{\hbar}{i}\frac{\partial}{\partial y}\psi)
I decided to factor out \frac{\hbar}{i}
(4)(\frac{\hbar}{i})^2(y\frac{\partial}{\partial z}-z\frac{\partial}{\partial y})\frac{\partial \psi}{\partial y}-(\frac{\hbar}{i})^2\frac{\partial}{\partial y}(y\frac{\partial \psi}{\partial z}-z\frac{\partial \psi}{\partial y})
Now I'm not sure what to do..
Now start expanding the derivatives in the second term using the product rule. Look for cancellations with symmetric partial derivatives like dy*dz vs dz*dy.
okay so then i got this
(5) (\frac{\hbar}{i})^2(y\frac{\partial}{\partial z}\frac{\partial\psi}{\partial y}-z\frac{\partial}{\partial y}\frac{\partial\psi}{\partial y})-(\frac{\hbar}{i})^2(\frac{\partial\psi}{\partial z}+y\frac{\partial}{\partial y}\frac{\partial\psi}{\partial z}-\frac{\partial z}{\partial y}\frac{\partial\psi}{\partial y}+z\frac{\partial}{\partial y}\frac{\partial\psi}{\partial y})
So then would y\frac{\partial}{\partial z}\frac{\partial\psi}{\partial y} y\frac{\partial}{\partial y}\frac{\partial\psi}{\partial z} cancel out? I'm not sure what you mean by cancel out haha, i have a really bad math foundation if you could please explain that would help a lot. Also did i do that last line correctly?
z\frac{\partial}{\partial y}\frac{\partial\psi}{\partial y} This term would also go away right?
Thanks for all your help!
1- The last term has a wrong sign.
2- By 'canceling out' one means finding a term with exactly the same form of a given term in the equation but with reversed sign so both would disappear. As in x+y-z-x=0, x and -x cancel out each other and the equation reduces to y-z=0.
2- Remember that derivatives have no order in the sense that \frac{\partial}{\partial x}\frac{\partial f(x,y)}{\partial y} = \frac{\partial}{\partial y}\frac{\partial f(x,y)}{\partial x}.
4- Now start canceling out terms and I'd recall that the derivative of coordinates wrt each other vanishes.
AB
what about the (partial z/ partial y) (partial psi/ partial y)?
What does that become?
Didn't you notice my fourth remark?!
AB
ahh I see what you mean. Thanks for all the help!
