Commutator question. [A,B] =.lambda proof
  • Thread starter Thread starter Jreyes613
    Commutator Proof
Jreyes613
Hello!
I'm having troubles with this proof.
given two operators A &B , such that [A,B] = λ where λ is complex,and μ is also complex, show that
exp{μ(A+B)} = exp{μA}exp{μB}exp{(-μ^2λ)/2}
[A,B] = λ.
[A,B] = AB-BA = λ
I have tried expanding the right side of the equation into three different exponentials by subbing in λ=AB-BA.
I get exp{μ(2A+2B-μAB+μBA}
but i seem to have a factor of two extra...
I'm not even sure if i am on the right track, so if anyone could give me a starting point it would be greatly appreciated!
It seems like maybe you tried adding the exponents on the right hand side. That's not allowed. If e^Ae^B generally is not equal to e^{A+B}. That would contradict what you are trying to show. Anyway, I'm not sure the best way to solve this problem, but what you are trying to show is.
\sum_{n=0}^\infty \frac{\mu^nA^n}{n!} \sum_{m=0}^\infty \frac{\mu^mB^m}{m!} \sum_{a=0}^\infty \frac{\left(-1\right)^a\mu^{2a}\lambda^a}{2^a a!}
=\sum_{b=0}^\infty \frac{\mu^b (A+B)^b}{b!}
You could try seeing if you can figure out where at the terms come from in the first expression.
(A+B)^0= 1
(A+B)^1= A + B
(A+B)^2= A^2 + 2AB - [A,B]+ B^2 = A^2 + 2AB + B^2 - \lambda
(A+B)^3= (A+B)\left( A^2 + 2AB + B^2 - \lambda\right)
However I'm really not sure exactly how to get this result.
That's the Baker-Campbell-Hausdorff formula. Search with Google and you will probably find help in the proof.
Thank you guys.
Yes , my TA said that you can use the Baker -Campbell-Hausdorff formula.
I will be able to solve it now, thanks!
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
