Comparing momentum and impulse of sleds
  • Thread starter Thread starter marcuss
    Impulse Momentum
The discussion focuses on comparing the momentum of two sleds with different masses, where one sled has a mass of 2m and the other has a mass of m. The primary formulas referenced are momentum (p=mv) and the relationship between force and momentum change (sigmaF=dp/dt). Participants highlight that both sleds have the same kinetic energy at the finish line, which allows for a connection between kinetic energy and momentum. By using the kinetic energy formula, they derive a relationship that helps demonstrate that the sled with mass 2m has a momentum of root2 compared to the sled with mass m. The conversation emphasizes the importance of relating energy and momentum to solve the problem effectively.
marcuss
1. The one sled has a mass of 2m and the other sled has a mass of m show that sled one with mass 2m has a momentum of root2 compared to the sled with mass m.
The only formulas that i could think to use were p=mv and sigmaF=dp/dt and i can't seem to find a way to relate them to get an answer so any help would be nice ty.
Was that the entire problem, or were you told anything else about the sleds? For example were their kinetic energies related somehow, or did they tell you something about their motion?
their kinetic energies were the same at the finish line
Kinetic energy = 1/2*m*v^2 = 1/2*(m^2*v^2)/m = 1/2*p^2/m
Use this relation between energy and momentum.
