Comparing summations with integrals
schniefen
1. Show that ##\sum_{n=1}^N \arctan{(n)} \geq N \arctan{(N)}-(1/2)\ln{(1+N^2)}##
2. Determine numbers ##\alpha##, ##\beta## such that ##\lim\limits_{N\to\infty} N^\alpha \sum_{n=1}^N \arctan{(n)} =\beta## with ##\beta \neq 0##
##\int_a^b f(x) dx= F(b)-F(a)##
1. ##\sum_{n=1}^N \arctan{(n)} \geq N \arctan{(N)}-(1/2)\ln{(1+N^2)} \iff \sum_{n=1}^N \arctan{(n)} \geq N \int_0^N \frac{1}{1+x^2} dx - \int_0^N \frac{x}{1+x^2} dx##
Where do I go from here? I've tried understanding this graphically, but to no avail.
2. Maybe this follows from finding an upper and lower bound for ##N^\alpha \sum_{n=1}^N \arctan{(n)}##, and then somehow applying the squeeze theorem?
You should write the right hand side as an integral of ## \operatorname{arctan}## and the left as an upper Riemann sum for this integral.
Likes schniefen
schniefen said:
Problem Statement: 1. Show that ##\sum_{n=1}^N \arctan{(n)} \geq N \arctan{(N)}-(1/2)\ln{(1+N^2)}##
Relevant Equations: ##\int_a^b f(x) dx= F(b)-F(a)##
This looks to me like a Riemann sum for an integral: ##\int_{x = 0}^N \arctan(x)~dx##, or maybe ##\int_{x = 1}^{N + 1} \arctan(x)~dx##. That's the approach I would take for starters.
Likes schniefen
If we have ##\sum_{n=1}^N \arctan{(n)} \geq \int_0^N \arctan{(x)} dx##, then ##N^\alpha \sum_{n=1}^N \arctan{(n)}## is simply the latter multiplied by a constant ##N^\alpha##. To obtain this expression in the first place, would it be reasonable to find an upper bound to the upper Riemann sum? Does it exist?
By the way, out of curiosity, how does one get ##\int_0^N \arctan{(x)} dx## from ##N \int_0^N \frac{1}{1+x^2} dx - \int_0^N \frac{x}{1+x^2} dx##.
I get
\iff N\int_0^N \frac{1-x}{1+x^2} dx ##
How does one incorporate the ##N## in the integral and turn this into ##\arctan##?
I do not understand your questions, sorry.
What does this mean? What expression? And why do you want to find an upper bound for something which is already an upper bound for something else? Why? What for?
In order ##N^\alpha \sum_{n=1}^N \operatorname{arctan} n## to converge, the ##\alpha## has to be so small, that it compensates the ##N\cdot\frac{\pi}{2}## term of the ##\operatorname{arctan}## as well as the increasing ##N##.
I get
I was talking about $$\int \operatorname{arctan}\frac{x}{a}\,dx = x\operatorname{arctan}\frac{x}{a}-\frac{a}{2}\log(a^2+x^2)$$ and not about the derivative.
I'm not sure how to differentiate ##\operatorname{arctan}##. I would try the inverse function theorem or a Weierstraß substitution to integrate ##\frac{1}{1+x^2}##.
Since
##N \arctan{(N)}-(1/2)\ln{(1+N^2)}=\int_0^N \arctan{(x)} dx##​
but ##N \arctan{(N)}-(1/2)\ln{(1+N^2)}## is also equal to
##N \int_0^N \frac{1}{1+x^2} dx - \int_0^N \frac{x}{1+x^2} dx = N\int_0^N \frac{1-x}{1+x^2} dx##
How does one get that ##N\int_0^N \frac{1-x}{1+x^2} dx =\int_0^N \arctan{(x)} dx## ?
Why is ##\pi \,\int_0^{\pi} \frac{4x}{\pi^3}\,dx = \int_0^{\pi} \operatorname{sin}x\,dx\,?##
Finite integrals are just a real number. So why are two different descriptions of a real number equal? Of course as ##\frac{d}{dx}\operatorname{arctan}x = \frac{1}{1+x^2} ## there are connections between those expressions. My suspicion is that this will lead to the Weierstraß substitution.
Okay. So ##N\int_0^N \frac{1-x}{1+x^2} dx## is not necessarily equal to ##\int_0^N \arctan{(x)} dx##?
Can there possibly be any ##\alpha## that compensates for this? Won't ##N^{\alpha}## yield ##[\infty]^{\alpha}## as ##N\to\infty##? If ##\alpha<0##, the limit ##\beta## will be 0 (but ##\beta\neq0##), and for all other ##\alpha## the limit will be infinite, or?
It is equal, you can calculate both sides. But what does it mean if two formulas yield the same result? In our case there are connections between ##\operatorname{arctan}x ## and ##\frac{1}{x^2+1}## but not obvious ones. As mentioned, I think the Weierstaß substitution is a good place for further investigations.
Write it down as your result. However, you have forgotten a case!
