badphysicist
- 80
Find I = \int_0^{2\pi} \frac{1}{cos\phi+b} d\phi
Given above..
This problem is an introductory problem to trigonometric functions and here is how the answer is obtained - but I have a question about it. First, here is the solution.
Use complex analysis. Make the substitution z=e^{i\phi} and cos\phi=\frac{e^{i\phi}+e^{-i\phi}}{2} to get \frac{1}{i}\oint_C {\frac{1}{z^2+2bz+1}dz} integrated over the unit circle contour.
We now find the poles: z_\pm=-b\pm \sqrt{b^2-1}.
However, as b goes to infinity, you see that the z_- goes to -infinity and z_+ goes to 0. Obviously, only z_+ stays inside the unit circle for |b|>1 so the solution is:
\frac{2\pi}{\sqrt{b^2-1}}
This is fine and I have no problem with this. This only applies for |b|>1 though. What about for |b|<=1? Well, obviously the integral diverges if you look back at the original integral. Here's my problem - if you try to use contour integration for |b|<=1, you will have to include the residues of both poles because both poles will be on the unit circle as b decreases. Wouldn't the residues cancel giving an answer of zero? What if b is actually a function and you want to do further integrations afterward with respect to a different variable? Thanks for any help on this.
