Complex Analysis Properties Question
The discussion centers on a complex analysis problem involving the expression of (sqrt(5)-i) and (2zbar+5). Participants identify a potential typo in the problem, noting that (sqrt(5)-i) should be expressed using absolute value signs. It is clarified that while (sqrt(5)-i) can be represented as sqrt(6) in terms of its magnitude, it cannot be equated directly to sqrt(3)*(2z+5). The conversation emphasizes the importance of correctly applying properties of complex numbers to avoid misunderstandings. Overall, the consensus is that there appears to be a typo in the original problem statement.
RJLiberator
Use properties to show that:
(question is in the attached picture)
Now, it is my understanding that due to properties you can express (sqrt(5)-i) as the sqrt((sqrt(5))^2+(-1)^2) which equals sqrt(6).
And (2zbar+5) can be represented as (2z+5).
But this would be sqrt(6)*(2z+5) which is NOT sqrt(3)*(2z+5)
Was there a typo in this problem? Or am I not thinking of something?
Thank you.
Thank you.
There are some absolute value signs missing, but yes, I think there is a typo.
Likes RJLiberator
Excellent. After performing the operations, I felt like I had a good understanding of it. This seems to confirm my suspicions :). Kind regards for your help tonight.
What you wrote here is very far from true. The real number ##\sqrt{6}## obviously can't be equal to ##\sqrt{5}-i##, which isn't even real. But Dick said something about missing absolute value signs, so I suppose you could be talking about something like this: For all ##z,w\in\mathbb C##, if ##\operatorname{Re}\bar z w=0##, then ##|z+w|^2=|z|^2+|w|^2##. This implies that ##|\sqrt{5}-i|^2=|\sqrt{5}|^2+|-i|^2=5+1=6##, and this implies that ##\sqrt{6}=|\sqrt{5}-i|##.
Likes RJLiberator
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
