Understanding Fourier Series: Complex vs. Ordinary Coefficients
zezima1
The Fourier series can also be written as:
f(x) = Ʃcr*exp(r*2π*i*x/L) where sum if from -∞ to ∞
My book says this at least, but I can't really determine the realitionship between the coefficients of an ordinary Fourier and the complex one. How do you get rid of the i that would appear in front of every sin factor, and how do you overall translate the coefficients cr to ar and br of an ordinary Fourier series?
Use Cauchy's formula:
e^{2ir\pi x/L}= cos(2r\pi x/L)+ i sin(2r\pi x/L)
Cosine is an even function and sine is an odd function so
e^{-\pi x/L}= cos(2r\pi x/L)- i sin(2r\pi x/L)
which is why you do not need negative values of r in the sine, cosine series.
\sum_{r=-\infty}^\infty a_re^{2ir\pi x/L}= (a_r+ a_{-r}) cos(2r\pi x/L)+ (a_r- a_{-r})i sin(2r\pi x/L)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
