Complex Numbers: Eigenvalues and Roots
The discussion focuses on solving problems related to complex numbers, eigenvalues, and roots, particularly the computation of (-81)^(1/4) using polar form and deMoivre's Theorem. Participants confirm that there are four complex roots for this expression, emphasizing the need to input results correctly into the computer system. The characteristic equation for a matrix yields three eigenvalues, prompting a discussion about whether to input three zeroes. There is also clarification on whether to use exact forms like sqrt(5) or decimal approximations in answers. Overall, the conversation highlights the importance of proper input format for complex number calculations in a computational context.
Canadian
[SOLVED] Complex Numbers: Eigenvalues and Roots
Below are some problems I am having trouble with, the computer is telling me my answers are wrong. It may be the way I am inputting the numbers but as my final is in a week and a half I would like to be sure.
Thanks,
All your answers look correct to me.
To compute (-81)^(1/4), can you write -81 in polar form? Then use the same method you used on the last problem.
I'm also getting (lambda)^3 = 0 for the characteristic equation on that first matrix. Since there are supposed to be three eigenvalues, could the computer want you to input three zeroes?
On the second one, you want to apply deMoivre's Theorem, as you did on the last problem, after writing -81 in polar form. There will be four complex roots (none of them real). [I can just barely read that, BTW: is that -81^(1/4) or -81^(3/4)?]
Your solution for the last problem looks to be correct. Does the computer accept expressions like 2^(1/3) cos (pi/9) as a part of a complex number or do you need to get out a calculator and find decimal approximations for the parts?
I'll have to get back to you shortly on the second eigenvalue problem.
Your answer to the third problem looks OK to me, too. Again, will the computer take sqrt(5) as an entry or do you need to give it 2.236? Make sure you are entering all your complex number results as two parts. You may need to check with someone as to what the acceptable form for complex number entry is.
Thanks for the help, the two eigenvalue questions were accepted after putting the answer in decimal form.
I'm headed off to bed now, will try the rest tomorrow morning.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
