Complex numbers, find (3/(1-i)-(1-i)/2)^40?
The discussion revolves around calculating the expression (3/(1-i)-(1-i)/2)^40, with participants confirming that the result simplifies to (1+2i)^40. One contributor suggests using polar form and de Moivre's theorem, noting the radius as sqrt(5) and the angle as 63.43 degrees for easier computation. Concerns about potential errors in the problem statement are raised, particularly regarding a possible misprint. Ultimately, the method of using de Moivre's theorem is affirmed as a valid approach to solve the problem accurately.
iamavisitor
Please help me find (3/(1-i)-(1-i)/2)^40. I got a result (see below) but I'm not sure whether it is correct. Any help is appreciated. Thanks.
I got (1+2i)^40. After this I got some funny numbers like 7^10*16*(6232-474*i).
I got (1+2i)^40.
I get this (above) also.
The way to go here is to convert 1 + 2i into polar form, using the Theorem of de Moivre. Then raising to the 40th power is easy.
See http://en.wikipedia.org/wiki/De_Moivre's_formula.
I know about de Moivre's formula. With it I get radius (r) to be sqrt(5) and angle 63.43 degrees. Again this is complicated to do by hand and I am wandering whether I got something wrong.
It is correct. But it might be that you or somebody else copied the problem wrong. (3/(1-i)-(1+i)/2)^40 would be easy.
ehild
No, it's not complicated to do by hand once you have the complex number in this form.
[r*e]n = rn*eniθ
