Complex numbers problem - lots of Algebra
The discussion centers around proving the identity involving complex numbers: \(\sqrt{\frac{1}{2}(a + \sqrt{a^2 + b^2})} + i\sqrt{\frac{1}{2}(-a + \sqrt{a^2 + b^2})} = a + ib\). Initial attempts to manipulate the equation by distributing terms and squaring both sides led to confusion, as the identity does not hold for all values of \(a\) and \(b\). A counterexample using \(a = 3\) and \(b = 4\) demonstrated that the equation is not universally true. It was clarified that the original statement is actually a form of Lagrange's identity, which requires squaring the left-hand side to verify the equality. The correct interpretation is that the expression simplifies to \(\sqrt{a + ib}\), highlighting the need for careful handling of square roots in complex analysis.
DrummingAtom
Show that \sqrt{\frac{1} {2} (a + \sqrt {a^2+b^2})} + i \sqrt{\frac{1} {2} (-a + \sqrt {a^2+b^2})}= a+ib
Distributed the i and then the 1/2's in each term which gave:
\sqrt{\frac{a} {2} + \frac{ \sqrt {a^2+b^2}}{2}}} -({-\frac{a} {2} + \frac {\sqrt {a^2+b^2}}{2}}) = a+ib.
Next I squared both sides to eliminate the roots, which gives:
\frac{a}{2}+\frac{\sqrt {a^2+b^2}}{2} - \frac {a^2}{4} - \frac {a^2+b^2}{4}+\frac {2a\sqrt{a^2+b^2}}{4}= a^2+2abi-b^2.
From that point it doesn't seem to work out. Was I going in the right direction?
Thanks for your help.
You lost the i on the left side.
As stated, you are supposed to show this is an identity, but it isn't. As a simple counterexample, let a = 3 and b = 4. Then
\sqrt{\frac{1} {2} (a + \sqrt {a^2+b^2})} + i \sqrt{\frac{1} {2} (-a + \sqrt {a^2+b^2})}= \sqrt{\frac{1} {2} (3 + \sqrt {3^2+4^2})} + i \sqrt{\frac{1} {2} (-3 + \sqrt {3^2+4^2})}
=\sqrt{\frac{1} {2} (3 + 5)} + i \sqrt{\frac{1} {2} (-3 + 5)} = 2 + i \neq 3 + 4i
So clearly the equation is not identically true for all values of a and b. Are you instead supposed to find values of a and b for which it is conditionally true? For two complex numbers to be equal, their real parts must be equal and their imaginary parts must be equal.
I got this out of Penrose's Road to Reality book, and actually I think I misread it. It's equation 4.3 @ http://mclerc.cl/penrosebook/book/RP/09_4_Magical%20complex%20numbers.pdf (Page 4 , half way down).
So, is he saying that that long equation (4.3) is equal a+bi? Or just the bulk of that equation can be viewed in a general form of a+bi?
No, what Penrose is saying is that the square of the long expression (it's not an equation) is a + ib. To verify that this is so, square the left side and it should simplify to a + ib.
This is known as the Lagrange's identity. Square the lhs and simplify and you should get the rhs.
EDIT:
I think you should have a square root above the whole expression on the rhs.
EDIT:
Not according to the reference. The actual statement is really
\left(\sqrt{\frac{1} {2} (a + \sqrt {a^2+b^2})} + i \sqrt{\frac{1} {2} (-a + \sqrt {a^2+b^2})}\right)^2= a+ib
EDIT:
Which is equivalent to
\sqrt{\frac{1} {2} (a + \sqrt {a^2+b^2})} + i \sqrt{\frac{1} {2} (-a + \sqrt {a^2+b^2})}= \sqrt{a+ib}
I guess he meant there are 2 square roots of a complex number.
