Complex variables- graphing an equation
sarahs52
Suppose that c is a member of the Real numbers, and p is a member of the Complex numbers with p not equal to 0, are given numbers.
(a) Show that pz + conjugate(pz) + c = 0 is the equation of a straight line in the plane.
Provide a carefully-drawn plot that illustrates your solution for a few given values of the constants c and p .
z is a complex number (i.e. x+iy)
a) After simplifying the conjugates: px +ipy + px - ipy + c = 0
After collecting like terms: 2px + c = 0
Solving for x: x = -0.5(c/p)
Now, I don't understand how the graph would look like. Would it be a vertical line on the real vs imaginary axes?
Thank you.
Looks like it to me.
Thank you.
I thought you said that p was a complex number; it does not appear so in what you have done.
RGV
p is a constant that is a member of the set of complex numbers. Does that make sense?
I see what you mean now, Ray. I think I got it now!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
