Explaining the Coefficient of a 45-Degree Rotation Vector
The discussion focuses on the mathematical representation of a complex vector that rotates counterclockwise in the x-y plane, specifically when phase-shifted by 45 degrees. The terms involving \(\frac{1}{\sqrt{2}}\) arise from the trigonometric values of cosine and sine at 45 degrees, where both equal \(\frac{1}{\sqrt{2}}\). This value is derived from the properties of a 45-degree right triangle, where the sides are equal, leading to these coefficients in the vector equation. Clarifications are provided regarding the correct notation and the relationship between the angles and their corresponding sine and cosine values. Understanding these coefficients is essential for grasping the behavior of the rotated vector.
jeff1evesque
A complex vector is written as,
\hat{v}(t) = cos(\omega t)\hat{x} + sin(\omega t)\hat{y} = \hat{x} + j\hat{y},
where \omega is the angular velocity, and the vector rotates counterclockwise in the x-y plane.If a unit vector is rotated in the x-y plane but is phase shifted by 45degrees, then:
\hat{v}(t) = (\frac{1}{\sqrt{2}} + j\frac{1}{\sqrt{2}})\hat{x} + \frac{1}{\sqrt{2}} - j\frac{1}{\sqrt{2}})\hat{x} \Rightarrow (cos(\omega t + 45^{\circ})\hat{x} + (cos(\omega t - 45^{\circ})\hat{y}
Can someone explain to me why there are terms \frac{1}{\sqrt{2}} in the equation above. I always thought a 45 degree triangle had sides of \sqrt{2}, \sqrt{2}, 2, but not sure how the coefficient \frac{1}{\sqrt{2}} is obtained.thanks,JL
Hi JL! :smile:
(you've got your x's and y'x mixed up … and you can get LaTeX to write big brackets "to fit" by typing \left( and \right) :wink:)
Because cos45º = sin45º = 1/√2 (a 45 degree triangle also has sides of 1, 1/√2, 1/√2) :smile:
