Simplifying Complex Circuits for Resistance Calculations
  • Thread starter Thread starter xxkbxx
    Resistance
The discussion focuses on simplifying a complex circuit to calculate resistance, specifically addressing the combination of resistors R5 and R6. It emphasizes using effective resistance notation, where resistors in parallel are represented as (R5 || R6) and combined with R4 in series. Participants suggest a systematic approach to reduce the circuit step-by-step, ultimately leading to an expression for total resistance. The final formula proposed for total resistance incorporates all resistors, ensuring clarity in calculations. This method enhances understanding and minimizes errors in circuit analysis.
xxkbxx
Okay - the picture is attached, but what I need to find is the current and voltage throughout certain points on the circuit. What I need help on is figuring out how to simplify this circuit in order to find resistance.
Parallel Req = (1/R1 + 1/R2)^-1
Series Req = R1 + R2
I know how to combine equations for series and parallel circuits - but what can I do with R4? I need to simplify the circuit, but I know I can't put it in parallel with R5 or R6 since it has resistance in both loops. Is there a way to combine R5 and R6. Let me know please...
I think R5 and R6 can be combined since you have only the one voltage source, then added to R4.
I tried that before, but I was unsure. The eq of R5 and R6 is (1/(R5) + 1/(R6))^-1 Then that would be added to R4, since R4 is in series. Okay, that makes more sense now - I think I have the rest from here!
I believe that tou can join the R5/R6 in parallel more the R4 in series to form a "block" with the R4 in parallel with this block
I believe that the circuit would be the same as the attachment from R1, R2, and R3 - but the last branch would have R5 and R6 in parallel in the "block" as you called it, in series with R4.
Would my total resistance than be:
Req = R1 + R2 + (1/(R3) + (1/R4) + (1/(1/R5 + R6))
Specifically, how would I add up the resistance of the R5 and R6 Block?
Right on.
But just wait til they start adding batteries all over.
I think that's close call R4+1/(1/R5+1/R6)=Z
Req=R1 + R2 + 1/(1/r3+1/z) is what I see.
R1+{1/R3+[(1/R5+1/R6)+R4]}+R2
R1+ \{ \frac{1}{R3} + (( \frac{1}{R5}+ \frac{1}{R6} )+ R4) \} + R2
Teach you a little trick to make these problems easier.
When two resistors R and r are in parallel, use the notation (R || r) to express the effective resistance. The two parallel lines '||' have an obvious meaning.
When two resistors R and r are in series, just add them up as usual, i.e. the effective resistance is R + r.
Now, your objective is to reduce the diagram in stages to a single resistance. Just forget about the mathematics and express everything in this notation at first.
When you reduce a pair of resistors, immediately redraw the diagram with the effective resistance of the pair as a single resistor. Just stick with the notation.
So, you'd begin : R5 is in parallel with R6, the effective resistance is (R5 || R6). That is now in series with R4, the effective resistance is now (R5 || R6) + R4, and so forth.
When you finally finish the reduction, you should get the effective resistance of the entire circuit (R) as :
R = {[(R5 || R6) + R4] || R3} + R2 + R1
(Be sure to bracket each pair of resistances as you reduce them, to avoid making a mistake).
Looks complicated, but it isn't really when you work through it yourself. It becomes a lot easier if you keep drawing the intermediate steps in the reduction with single resistances replacing the pairs you've reduced.
Now just apply the relation R || r = (1/R + 1/r)^(-1) = (Rr)/(R+r), while taking care with the brackets, and you've got the effective resistance of the circuit.
Slick, I like that. Improves legibility, reduces chance for error, avoids the need to make subs as I did...
Wait till you see how legible they make (otherwise) complicated complex impedance problems! :smile:
