Composite and one to one function
brad sue
Hi,
I have this question:
if f and f \circ g are 1 to 1 functions, does it follow that g is 1-1 function?
My answer is NO g doesn't have to be 1-1 function.
for example ,
if g(3)=4 and g(7)=4,
then f( g(3) )= f( G(7) )=f(4) will produce the 1-1 function property.
Is my reasonning OK??
B
The best way to look at "true/false" questions like this is often to try to prove whatever it's asking, and if you can't, then see if you can build a counterexample by paying attention to what "breaks" your proof.
Your counterexample doesn't work, since then you'll have, as you wrote, (f\circ g)(3) = (f\circ g)(7), which obviously means f \circ g is not 1-1.
So try to see if you can prove it. I'd suggest doing it by contradiction.
(And just to remind you, a function h is 1-1 iff h(x) = g(y) implies x=y).
Ok thank I found the problem
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
