MHB Composite functions and substitutions Quick Question
The discussion revolves around determining the domains of composite functions f o g and g o f, with the user initially stating their findings. They assert that the domain for f o g is [-1, infinity) and for g o f is [27, infinity), but later corrections indicate that the correct domain for g o f is [2, infinity). The user also correctly identifies the domains for f o f and g o g as [6, infinity) and [-5, infinity), respectively. For the second question, the user finds f o g = 3/(3-2x) with a domain of (-infinity, 3/2) u (3/2, infinity), while the domain for g o f is (-infinity, 0) u (0, 2) u (2, infinity). The discussion emphasizes the importance of accurately determining the domains based on the conditions set by the functions.
ardentmed
Hey guys,
I have a couple more questions about this problem set I've been working on. I'm doubting some of my answers and I'd appreciate some help.
Question:
For the first one, since f o g = √(√x+5)-2), the domain is [-1,infinity)
Likewise, g o f = √(√x-2)+5) and the domain is [27,infinity) since x-2 >= 25.
Also, since f o f = √(√x-2)-2), the domain is [6,infinity) because √x-2) >= 2 which means x >=6.
Furthermore, since g o g = √(√x+5)+5), the domain is [20,infinity) because √x+5) >= -5 which means x >= 25-5
As for the second question, f o g = 3/(3-2x) via simple substitution. And since x cannot = 3/2, the domain is:
Please tell me if I'm on the right track.
Thanks again guys.
Mathematics news on Phys.org
ardentmed said:
Hey guys,
Question:For the first one, since f o g = √(√x+5)-2), the domain is [-1,infinity)
Thanks again guys.
Hi! (Wave)
For the first subquestion,it is like that:
$$f(g(x))=\sqrt{\sqrt{x+5}-2}$$
It must be:
$$x+5 \geq 0 \Rightarrow x \geq -5$$
AND
$$\sqrt{x+5}-2 \geq 0 \Rightarrow \sqrt{x+5} \geq 2 \Rightarrow x+5 \geq 4 \Rightarrow x \geq -1 $$
Therefore,$x \geq \max \{ -1,-5\} \Rightarrow x \geq -1$
So,the domain of $f \circ g$ is $[-1,+\infty)$,as you said!
$$g \circ f=g(f(x))=\sqrt{\sqrt{x-2}+5}$$
It must be:
$$x-2 \geq 0 \Rightarrow x \geq 2$$
AND
$$\sqrt{x-2}+5 \geq 0 \Rightarrow \sqrt{x-2} \geq -5 \text{ ,which is true } \forall x$$
Therefore, $x \geq 2$
So,the domain of $g \circ f$ is $[2,+\infty)$.
The domain of $f \circ f =\sqrt{\sqrt{x-2}-2}$ is $[6,+\infty)$ as you correctly mentioned.
$$g \circ g= \sqrt{\sqrt{x+5}+5}$$
It must be:
AND
$$\sqrt{x+5}+5 \geq 0 \Rightarrow \sqrt{x+5} \geq -5 \text{ which is true } \forall x$$
Therefore,the domain of $g \circ g$ is $[-5,+\infty)$.
For the second subquestion,it is like that:
For the second subquestion:
$$f \circ g=\frac{\frac{3}{x}}{\frac{3}{x}-2}=\frac{3}{3-2x}$$
It must be :
$$x \neq 0 \text{ , and also } 3-2x \neq 0 \Rightarrow x \neq \frac{3}{2}$$
Therefore,the domain is:
$$(-\infty,0) \cup (0,\frac{3}{2}) \cup (\frac{3}{2},+\infty)$$
$$g \circ f=\frac{3}{\frac{x}{x-2}}=\frac{3(x-2)}{x}$$
It must be:
$$x \neq 2 \text{ and } x \neq 0$$
$$(-\infty,0) \cup (0,2) \cup (2,+\infty)$$
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
