Composite Functions: f o g (x) = Abs(x), f(x) = root(x), g(x) = Abs(x)
The discussion revolves around the composite functions f o g (x) = Abs(x), f(x) = root(x), and g(x) = Abs(x). Participants debate whether f(x) should be equal to sqrt(x) or if g(x) should be sqrt(x) instead. Clarifications are made regarding the correct interpretation of the problem, with some suggesting that if f o g (x) = Abs(x), then f(x) could be x^2 and g(x) = sqrt(x). The domain of g is noted as x ≥ 0, leading to the conclusion that x = |x| in this context. The conversation emphasizes the importance of correctly identifying the functions involved in the composite.
Larrytsai
f o g (x) = Abs(x)
f(x)=?
g(x)= root(x)
im thinking f(x) is = to root(x) correct me if I am wrong?
f(x) = sqrt(x) doesn't work. Are you sure you have this problem written correctly? Could it be g o f (x) = Abs(x)? That would make more sense with g(x) being sqrt(x). Of if it is indeed f o g (x) = Abs(x), could it be that f(x) = sqrt(x) and you need to find g(x)?
its correct way i took it straight from the book.
OK.
If f(x) = x2 and g(x) = \sqrt{x}
then (f~\circ~g )(x) = x.
Since the domain of g = {x | x \geq 0}, then x = |x| in this case.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
