Determining Steel String Diameter for Standing Wave Node
Firben
The figure below shows a snapshot of a standing wave on a composite string. It is a node in the composite point. If the aluminium string has a diameter of 1.50 mm, which diameter does the steel string have ?
http://s716.photobucket.com/user/Pitoraq/media/Fys22222_zps61d0eb53.png.html
V = √(F/ρ(length)) = √(F/ρA)
Al: Node in both endpoints
y = f(ωt)*sin(kx) <==> sin(k1L1) = 0 <==>
2π/λ1*L1 = P1π <==>
λ1 = 2/p1*L1
Steel: Node in both endpoints
sin(K2L2) = 0 <==> 2π/λ2*L2 = P2π <==>
λ2 = 2/p2*L2
λ = v/f
λ1 = v/f1 = 2/p1*L1 <==> vp1/2L1 = f1 <==>
vp2/2L2 = f2
Same frequency
vp2/2L2 = vp1/2L1 <==>
√(F/ρ(al)A1)*P1/2L1 = √(F/ρ(Steel)A2)*P2/2L2 <==>
√(F/ρ(al)4πd1)*P1/2L1 = √(F/ρ(Steel)4πd2)*P2/2L2 , breaking out d2 <==>
d2 = ((p2)^2*(L1)^2*(ρ(Al))*d1)/((p1)^2*(L2)^2*ρ(Steel))
Where d1 = 0.0015
ρ(Al) = 2.7+ * 10^3/m^3
ρ(Steel) = 7.87*10^3/m^3
L1 = 0.3 m
L2 = 0.25 m
p2 = 5
p1 = 3
Are the nodes from the figure
when i put does values into the equation above i got 2.058 * 10^-3 m
In the answer it should be 1.76 mm
I think if you are more careful writing the equations (especially the grouping under the square roots) you'll can see more clearly where the problem is. I'll rewrite some of it
Starting from:
Firben said:
Same frequency
\begin{align}
\frac{vp_2}{L_2} &= \frac{vp_1}{L_1} \\
\frac{p_2}{L_2} \sqrt{\frac{F}{\mu_2}} &= \frac{p_1}{L_1} \sqrt{\frac{F}{\mu_1}} \\
\frac{p_2}{L_2} \sqrt{\frac{F}{\pi(d_2/2)^2\rho_\mathrm{Steel}}}
&= \frac{p_1}{L_1} \sqrt{\frac{F}{\pi(d_1/2)^2\rho_\mathrm{Al}}} \\
\frac{p_2/L_2}{p_1/L_1} \sqrt{\frac{\rho_\mathrm{Al}}{\rho_\mathrm{Steel}}}
&= \frac{d_2}{d_1}
\end{align}
So it seems as if you forgot d1, d2 were inside the √ and as a result your p1, L1, p2, L2 got squared by accident.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
