Compression of a spring by an object in free fall
8 replies · 3K views
hawkeye1029
A 2.0 kg object starting at rest falls 3.0 m onto a 4.0 N/m spring. How far will the spring be compressed?
m = 2.0 kg
vo = 0 m/s2
y = 3 m
k = 4 N/m
g = -9/8 m/s2
eq1: Fg = mg
eq2: Fspring = -kx
[/B]
eq1: Fg = mg
Fg = (2.0kg)(9.8m/s2)
Fg = 19.6N
Fspring = -kx
19.6N = (-4N/m)x
x = -4.9m -> compressed 4.9m
Since they gave y = 3m, I feel like I need to use it, but I'm not sure where. The answer key says the correct answer is 5.42m.
Thank you for any help.
Well, you can kind of imagine the amount of compression depends on the height from which the object is dropped ... :rolleyes:
What you describe is placing the object on the spring and gently lower it until equilibrium is reached.
Looks to me like the answer key didn't account for the additional GPE converted as the spring compresses.
OK, so then I would need to use Conservation of Energy? Potential energy of block -> kinetic energy -> potential energy in spring?
mgh = 1/2kx2
x2 = 2mgh/k
x = 5.42m
Do you mean the GPE of the block when it's resting on the spring?
mgh = 1/2kx2
x2 = 2mgh/k
x = 5.42m
Yes, energy is the easiest way to solve a problem like this. It gains kinetic energy from the GPE of falling 3.0 meters plus the additional distance ##x## as it compresses the spring. All of that energy is converted into spring compression energy.
As @gneill says above, it looks like the answer key didn't account for the additional energy ##mgx## from falling that extra distance ##x##.
No, I mean the GPE that is converted to KE (and hence to spring PE) while the block is still dropping and compressing the spring. The spring doesn't just fall through 3 m. That 3 m fall just brings it into first contact with the spring. As the spring compresses, the block continues to drop along with the top of the spring.
Ohh I see. As I'm in beginning physics and this is a problem at the start of a new unit, I think the teacher didn't want to confuse us.
If I did want to take that into account, how would I go about doing that?
It would be a lot more confusing if you were starting out with incorrect information and having to un-learn it later :smile:
The ball falls an extra distance equal to the compression distance of the spring. It's the same x that you're looking for.
See my answer. Add a term on the left to account for the object falling an extra distance ##x##.
