Visible Spectrum and the Compton Effect
In summary, the Compton effect is not noticeable when using light from the visible spectrum because the energy of the photon determines the momentum of the photon.
wolfgang
Hi,I need some help here.
Why the Compton effect can not be noticed when we are using light from the visible spectrum?
The energy of the photon also determines the momentum of the photon. That is, a high energy photon is a high momentum photon.
In the Compton effect, an electron recoils after a collision with a photon, and this recoil acts just like a classical conservation of momentum collision.
A visible photon has much less energy than an x-ray. We're talking a thousandth to ten-thousandth less energy, and therefore that much less momentum.
A collision with a visible photn whould knock an electron into a higher shell, temporarily, but much more energy is required to knock it completely out of the material
what is the Compton effect?
The question remain.
Thanks for trying to answer me Mr Chi but my problem remain,I will make myshelf clear.
If the wavelength of the X-ray photon before the collision with the electron is ë then after the collision the wavelength of the X-ray becomes bigger because the X-ray photon looses a part of its momentum because of the interaction with the electron.
Let’s call this new bigger wavelength ë’. When we are using X-rays the Compton effect is noticeable because the difference ë’-ë is measurable, but when we are using visible photons the ë’ is equal to ë and we can not notice the Compton effect.
And my question is the following:
The wavelength does not change because the ë of the visible photon is 100000000 times bigger than the diameter of the electron and so the photon actually can not see the electron? or because the changing of the momentum during the collision is so small that the difference between ë’ and ë can not be measured in our labs?
What is really happening I am very curious,aren't you?
The wavelength shift in the Compton effect depends only on the mass of the particle with which the effect takes place. The maximal shift occurs when the photon bounces back at 180 degrees. For The Compton effect with a photon and an electron' the change in wavelength is about 0.02 Angstroms. So when your photon is in the visible light, you just cannot see this difference.
more questions
You are obviously talking about the equation of Compton:
ë´- ë= L(1- cosö).
Where L is equal to L=h/mc=0.02426 Angstroms (for the electron) so the shift ë´- ë of the photon is between 0 < ë´- ë < 0.04852 Angstroms
(because 0< 1-cosö < 2).
We know that the modern spectrometers has resolving power of 0.01 Angstroms so we can measure shifts of the wavelength which are bigger than 0.01 Angstroms. This means that:
ë´- ë > 0,01 Á and ëc(1- cosö) > 0.01 A if we do the calculations we will get that we can measure shifts of the wavelength when the change of the angle is bigger than 54 degrees.
If my thoughts are correct then the Compton effect is not noticeable when the change of the direction of the visible photon during the collision with the electron is smaller than 54 degrees? Is that correct??
Can we say that the Compton effect with a visible photon and an electron it is noticeable only when ö>54 degrees?
The frequency of a monochromatic source is never completely monochromatic (Due to Heisenberg's uncertainty principle), it has a finite spectral width (linewidth). The natural linewidth (Linewidth due to HUP), is usually around 8 MHz, which corresponds to a wavelength difference of around 0.03 angstroms in the visible, which is roughly the same wavelength change induced by the compton shift.
Hence it is quite impossible to spectrally differentiate between the Compton shifted radiation and the original source.
Claude.
Oh, I like that! I was doing the math trying to come up with an answer but... I don't think I've ever come across this explanation before.
I totally believe your explanation, Claude, it makes total sense; but could you name a text, or website, or book that corroborates this?
TIA
Any textbook with a section on lasers will probably deal with spectral linewidths.
'Laser Electronics' by Verdeyen, 'Lasers and Electro-Optics' by Davis and 'Laser Fundamentals' by Silfvast are a few examples.
Hyperphysics has a decent page on natural linewidths: http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/parlif.html
Claude.
Thanks. My books are a little old; so's my memory it seems: can the Compton effect be observed when x-rays rebound from metals? I seem to remember that it is, but I can't find any reference to it.
Hi,
Indeed Claude Bile your explanation was very clever.
I would not think of it.
Thank you anyway :wink:
"The only thing I know is that
I don't know anything"
Socrates
Hi,
I think that this not so “simple” as the collision between an X-ray photon and an electron. This is because here appears the photoelectric effect.
The free electrons of the metal can absorb only photons that have energy bigger than the extraction work of the metal.
So if the X-ray has energy equal or bigger than the extraction work then there is no X-ray rebounding because it is absorb by the electron. But if the X-ray’s energy is less than the extraction work we can notice the Compton effect.
Socrates
The Compton effect occurs primarily in the absorption of high X-ray energy and low atomic numbers. The effect takes place when high X-ray energy photons collide with an electron. Both particles may be deflected at an angle to the direction of the path of the incident X-ray. The incident photon having delivered some of its energy to the electron emerges with a longer wavelength. These deflections, accompanied by a charge of wavelength are known as Compton scattering.
Related to Visible Spectrum and the Compton Effect
1. What is the visible spectrum?
The visible spectrum is the portion of the electromagnetic spectrum that is visible to the human eye. It ranges from approximately 400 to 700 nanometers and is made up of the colors red, orange, yellow, green, blue, indigo, and violet.
2. How does the visible spectrum relate to light?
Light is a form of electromagnetic radiation that travels in waves. The visible spectrum is the range of wavelengths of light that the human eye can detect. When all the colors of the visible spectrum are combined, they form white light.
3. What is the Compton Effect?
The Compton Effect is a phenomenon in which the wavelength of a photon (particle of light) changes after it collides with a free electron. This effect was first observed by Arthur Compton in 1923 and provided evidence for the particle-like nature of light.
4. How does the Compton Effect explain the colors we see?
When a photon of light interacts with an electron, it transfers some of its energy to the electron. This causes the photon's wavelength to increase, shifting it towards the red end of the spectrum. This explains why red objects appear red, as they absorb and reflect more red light than other colors.
5. What are the practical applications of the Compton Effect?
The Compton Effect has many practical applications, including in medical imaging, where it is used in X-ray technology to produce detailed images of bones and tissues. It is also used in radiation therapy to target and destroy cancer cells. In addition, the Compton Effect is used in airport security scanners to detect hidden objects in luggage.
  • High Energy, Nuclear, Particle Physics
  • Other Physics Topics
  • General Discussion
  • Biology and Chemistry Homework Help
