How Much Air Can Be Heated with the Same Energy Used to Warm Water in a Kettle?
The discussion centers on calculating how much air can be heated using the same energy that warms 1 kg of water from 20°C to 30°C. The energy required to heat the water is calculated to be 41,900 J. Participants explore the heat capacity of air and its density to determine the mass of air that can be heated under the same conditions. The correct formula for mass is debated, with emphasis on ensuring unit consistency. The final answer for the mass of air that can be heated is determined to be approximately 5.65 kg.
Firben
You warm 1.00 kg of water at a constant volume of 1.00 L from 20.0 degrees C to 30.0 degrees C in a kettle. For the same amount of heat, how many kilo grams of 20.0 degree C air would you be able to warm to 30.0 degree C? What volume would this air occupy at 20.0 degrees C and a pressure of 1.00 atm? Make the simplifying assumption that air is 100% N2.
m = 2CvQ/(3RΔTcv)
ρ=m/v
dQ = mcdT
Q = (1.00kg)(4190 J/mol*K)(303K-293K) = 41900 J
c(air) = 1.01 * 10^3 J/kg*K
V= 1.00 L
ρ(air) =1.2929 kg/m^-3
m(air) = ρ(air)*V <=>
m(air) = (1.2929 kg/m^-3)(1.00 L) = 1.2929 kg
C(air) = (1.01*10^3 J/kg*K)(1.2929 kg) = 1305.829 J/mol*K
R = 8.314 J/mol*K
cv = 4190 J/mol*K
the answer should be 5.65 kg
Hint: you ignored V=const part.
Is this formula right m = 2CvQ/(3RΔTcv) ?
Argh, what was I thinking. You used wrong heat capacity value, but not because of the constant volume, you just have your units wrong. Sigh.
Check your units. Is the result in kg?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
