Compute Lim Inf & Lim Sup of Sequence
  • Thread starter Thread starter tracedinair
The discussion revolves around the computation of the limit inferior and limit superior of a sequence derived from an infinite series, specifically the series defined by the terms 1/2 + 1/3 + 1/(2^(2)) + 1/(3^(2)) + 1/(2^(3)) + 1/(3^(3)) + ... Participants are exploring the nature of the sequence and its terms to compute various limits.
  • Participants discuss the definition of the sequence associated with the infinite sum and the need to clarify the terms involved. There is an exploration of the ratio and root tests, with some participants questioning the interpretation of terms as either positive and negative cases or odd and even terms. Attempts to define the sequence in terms of partial sums and the general term are noted.
The discussion is ongoing, with participants providing insights and clarifications about the sequence and its terms. Some have offered guidance on how to approach the limit calculations, while others are seeking further clarification on specific aspects of the problem, particularly regarding the even and odd terms of the sequence.
There is a noted confusion regarding the distinction between positive and negative cases versus odd and even terms in the sequence. Participants are encouraged to define the terms clearly to facilitate further discussion.
tracedinair
Given the sequence, 1/2 + 1/3 + 1/(2^(2)) + 1/(3^(2)) + 1/(2^(3)) + 1/(3^(3)) + ..., Describe the terms of the sequence and use it to compute the lim inf (a_n+1)/(a_n); lim sup (a_n+1)/(a_n); lim inf (a_n)^(1/n); lim sup (a_n)^(1/n).
First, I found the formula for the sequence, which is [tex]\Sigma[/tex] i=1 to infinity of [1/(2^(i)) + 1/(3^(i))].
I wrote out some terms of the sequence, but I'm having a hard time pulling out a subsequence to compute the ratio and root tests.
First off, 1/2 + 1/3 + 1/(2^(2)) + 1/(3^(2)) + 1/(2^(3)) + 1/(3^(3)) + ... is an infinite sum (AKA infinite series), not a sequence. Every infinite sum has a sequence associated with it, the sequence of partial sums, {Sn}, which is defined this way:
[tex]S_n~=~\sum_{i = 1}^n a_n[/tex]
Is an defined for your infinite sum? If not, it would be more convenient to define the general term in your series as an = 1/2n + 1/3n. If an is defined in this way or can be defined this way, the ratio an + 1/an is fairly easy to calculate, and comes out to (3n+1 + 2n+1)/(6(3n + 2n)). You should be able to work with this to get your lim sup and lim inf values
On the other hand, if an has a different formula for the even terms and the odd terms, it's going to be more difficult to calculate the aforementioned ratio.
The second part of the problem says I should consider both cases, positive and negative, when computing the lim inf and lim sup. I've never seen this type of problem before and I'm totally sure what it is asking me to do.
You didn't include that information in your problem description. What do you mean, both cases, positive and negative?
Yeah, both cases positive and negative.
Again, what do you mean by the positive and negative cases?
From my notes: After writing down a formula for {a_n}, describe {a_n} when n is even (n=2k) and when n is odd (2k-1).
That information would have answered my questions in post #2. This doesn't have anything to do with positive and negative, but rather, odd and even terms.
So finally, we're getting somewhere.
Here are some more questions.
What do the a2k terms of this series look like?
What do the a2k - 1 terms look like?
If these are too hard, what do a2, a4, a6, and so on look like? Can you generalize this?
What do a1, a3, a5, and so on look like? Can you generalize this?
How are you getting the lim inf and lim sup vales out of (3n+1 + 2n+1)/(6(3n + 2n))?
I'm not. Look at post #8 again, and answer the questions I've asked.
