devilaudy
- 7
- 0
https://www.dropbox.com/s/17hsoz0zdfoston/Screen shot 2013-05-10 at 12.37.44 PM.png
1) A voltage is applied to a solenoid such that a current is flowing in the indicated direction. Inside the solenoid is a single wire loop that is oriented in the same direction as the solenoid windings.
Which one of the following statements is true in the case where the voltage applied to the solenoid is increased?
a) The magnetic field of the solenoid points to the left while the induced current at location A points out of the paper.
b) The magnetic field of the solenoid points to the right while the induced current at location A points into the paper.
c) The magnetic field of the solenoid points to the left while the induced current at location A points into the paper.
d) The magnetic field of the solenoid points to the right while the induced current at location A points out of the paper.
2) Which one of the following statements is true in the case where the voltage applied to the solenoid is increased?
a) The magnetic dipole moment of the loop points to the right.
b) The torque on the loop points into the paper.
c) The torque on the loop points out of the paper.
d) The magnetic dipole moment of the loop points to the left.
e) A voltage is only induced in the inner loop, not in the solenoid itself.
Lenz's law
I thought the answer to question 1 was c) since the magnetic field would point in the opposite direction to fight the increase in magnetic flux, but it was wrong. I have no idea where to start for the second question. Thanks in advance!
