Conductivity Tensor: Problem 4.7 Purcell Analysis
psholtz
I'm working through Problem 4.7 in Purcell, on conductivity tensors.
We build a conductor by alternately stacking plates of tin and silver (differing conductivities). When we pass a current through this "composite" conductor, we will get a different value for the conductivity depending on whether we apply the current (a) parallel; or (b) perpendicular to the plates.
Let \sigma_1 designate the conductivity of the silver plate, and \sigma_2 designate the conductivity of the tin.
The silver plate is 100 angstrom thick, and the tin plate is 200 angstrom thick.
We are seeking the "ratio" of \sigma_{\perp} / \sigma_{\parallel}
The important equation is the "microscopic" version of Ohm's Law:
\mathbf{J} = \sigma \mathbf{E}
First let's derive a value for \sigma_{\perp}, which is to say, the conductivity we get when passing the current perpendicular to the plates. The current density must be the same in both regions (silver and tin). Because the conductivities of the metals differ, we must have a charge layer that builds up at the junction between the metal plates. In other words:
J_1 = J_2
\sigma_1 E_1 = \sigma_2 E_2
and since \sigma_1 > \sigma_2, we must have E_1 < E_2.
Let E_0 be the 'net" electric field driving the (uniform) current density in both regions (i.e., J_{net} = \sigma_{net} E_0 = \sigma_{\perp} E_0). We have:
E_1 = E_0 - E_{charge layer}
E_2 = E_0 + E_{charge layer}
from which we obtain:
\large{ E_0 = \frac{1}{2}(E_1 + E_2)}
\large{E_0 = \frac{J}{2}(\frac{1}{\sigma_1} + \frac{1}{\sigma_2})}
\large{E_0 = \frac{J}{2}( \frac{\sigma_1 + \sigma_2}{\sigma_1 \sigma_2} )}
\large{J = \frac{2 \sigma_1 \sigma_2}{\sigma_1 + \sigma_2} E_0 }
From which we conclude:
\sigma_{\perp} = \frac{2 \sigma_1 \sigma_2}{\sigma_1 + \sigma_2}
Note that if \sigma_1 = \sigma_2 = \sigma, we have:
\sigma_{\perp} = \frac{2 \sigma^2}{2 \sigma} = \sigma
which is the result we expect.
Now let's derive the "parallel" conductivity. Again, we will have a net "applied" electric field E_0 but this time, the applied field will produce two distinct current denstities in the respective metal layers. The "net" current density, the one we will use to calculate the "parallel" conductivity of the material, will be the vector sum of these two (in other words, there will be no net charge layer). We have:
J_1 = \sigma_1 E_0
J_2 = \sigma_2 E_0
Bearing in mind that the silver layer (sigma 1) is 100 ang thick, and the tin layer (sigma 2) is 200 ang thick, we have:
J_{total} = J_1 + J_2 = \frac{\sigma_1 + 2\sigma_2}{3} E_0
So that:
\sigma_{\parallel} = \frac{\sigma_1 + 2\sigma_2}{3}
Again, if \sigma_1 = \sigma_2 = \sigma, we have:
\sigma_{\parallel} = \frac{\sigma + 2\sigma}{3} = \sigma
which is the expected result.
The ratio we initially set out to calculate is thus:
\sigma_{\perp} / \sigma_{\parallel} = \frac{6 \sigma_1 \sigma_2}{(\sigma_1 + \sigma_2)(\sigma_1 + 2\sigma_2)}
If we suppose that \sigma_1 = k\sigma_2 this reduces to:
\sigma_{\perp} / \sigma_{\parallel} = \frac{6 k \sigma_2^2}{(k\sigma_2 + \sigma_2)(k\sigma_2 + 2\sigma_2)} = \frac{6 k \sigma_2^2}{(k + 1)(k + 2)\sigma_2^2}
\sigma_{\perp} / \sigma_{\parallel} = \frac{6k}{(k+1)(k+2)}
Taking k=7.2, we have:
\sigma_{\perp} / \sigma_{\parallel} = 0.573
However, the answer in the book is 0.457.
What am I doing wrong?
Your $\sigma_\perp$ equation is wrong. It should be $\sigma_\perp = \frac{3 \sigma_Ag \sigma_sn}{\sigma_Sn + 2 \sigma_Ag}$.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
