Confirm correctness of simple Newton's second law-type problem?
  • Thread starter Thread starter zero_infinity
The discussion revolves around solving a Newton's second law problem involving a 4kg mass influenced by two forces over time. The initial velocity is given, and the forces are expressed as functions of time. Participants are verifying calculations for the object's velocity at t=3 seconds, the time it stops moving in the j direction, and its displacement at t=6 seconds. Key steps include calculating acceleration from the forces, applying kinematic equations, and ensuring proper integration of acceleration and velocity components. The conversation emphasizes the importance of separating the i and j components for accurate results.
zero_infinity
at t=0, a 4kg mass is moving at 2 m/s\hat{i} + 3m/s\hat{j}
at t=0, F1 and F2 act upon the object
F1= [1 N + (1/2 N/s)t ]\hat{i}
F2= -(1/3 N/s2)t2 \hat{j}
a) what is the object's velocity when t=3?
b) at what time does the object stop moving in \hat{j} direction?
c) what is the object's displacement when t=6?
F=ma
kinematics
just look at the steps and see if I'm doing it right please
\vec{V}0 = 2 m/s\hat{i} + 3m/s\hat{j}
\vec{F}(t) = [1 N + (1/2 N/s)t ]\hat{i} - (1/3 N/s2)t2 \hat{j}
(a)
\vec{F}(t) = m\vec{a}
\vec{F}(3)/4 kg = \vec{a}
Use \vec{V}f = \vec{V}0 + \vec{a}t
\vec{V}f = 21/8 \hat{i} - 3/4 \hat{j}
(b)
just look at the \hat{j} component of the vector
\vec{F}j(t)/ 4kg = \vec{a}j
0 = 3m/s\hat{j} - \vec{a}jt
t = 3.30 s
(c)
\vec{F}(t)/ 4kg = \vec{a}(t)
actually, now when I'm rewriting it, I'm not sure how to integrate \vec{a}
do i integrate the acceleration from 0 to 6? i don't think so...
i integrated acceleration (not accounting for C) and then integrated velocity from 0 to 6 (this is obviously wrong now that I'm looking over it)
Find the velocity and acceleration along i and j directions separately.
Using proper kinematic equations find the remaining answers by using vector addition.
Hi
which part are you talking about?
Voi = 2 m/s, F1i = 1N. Find a1i.
Similarly find Voj, F2j and a2J.
Calculate Vfi and Vfj after 3 s.
