Confused about energy in a system (Understanding)
The discussion centers on understanding the energy dynamics of a ball falling onto a spring. The total energy absorbed by the spring is derived from both the kinetic energy of the ball and gravitational potential energy, expressed as 1/2 mv² + mgx. The average force exerted by the spring can be calculated using the mean value theorem, with the relationship F_avg = (Ff - Fi)/2, where F is the force. The confusion arises from distinguishing between work done on the spring and the energy stored in it, emphasizing that work is not equivalent to energy. Ultimately, the energy stored in the spring is correctly represented as E = 1/2 kx², where the factor of 1/2 accounts for the average force during compression.
qazxsw11111
Take for example, a ball falling on a spring. Before touching the spring, the ball has velocity v. Then x metres of spring is compressed.
Total energy that is lost in the spring=1/2 mv2+mgx
When the spring is compressed for x m, it has 1/2 (F) (x) J of energy, right?
So to find the average F exerted by spring, should I combine the two equations together to find f?
However, my teacher said that the first equation should be linked to Fx as work is done by the ball. Thats another way of looking at it though, but the answer is different obviously. How do you explain it? I know it is my misunderstanding, can anyone help me see the light?
Thanks.
This would be the total energy absorbed by the spring, not lost.
No, I don't think so. If you take away the 1/2 then that will be the relationship for work done on the spring. In other words,
Work = F x X
But work is not the same as energy, do you know the difference?
Combine which two equations? Ideally, you would find the average force by applying the mean value theorem on F = -kx. But since this is a simple and ideal problem you could just find the total change in force on the spring and divide by 2. Or,
Favg = (Ff-Fi)/2
Should be linked to Fx in what way? The equation you had up there looks correct to me. To total potential energy in the spring should the kinetic energy that was in the ball along with any potential energy from a gravitational force.
PEspring = 0.5*m*V^2 + m*g*x = 0.5*-k*x^2
OK. That's the energy stored in the spring when compressed to the max from the ball.
Not sure what this is. What's F? Are you trying to calculate the work done? You could say that the energy stored = F_ave * x, where F_ave is the average force exerted by the spring.
Usually one expresses the energy stored in the spring in terms of the spring constant (which determines the force as a function of x) as well as x. Do you know that result?
Maybe you can rephrase your question.
Work = F x X
Favg = (Ff-Fi)/2
Ahh yes. My mistake typo there. I think it is energy lost by the ball to the spring. But isn't the energy equation for a spring is 1/2 F x, where F is the average Force and x is the distance compressed? I thought by conservation of energy, PE+k.e lost by ball=1/2 Fx, which my teacher said that it should be PE+KE=Fx.
BTW, I am trying to find the average force and F is the force, Doc Al.
No. Why would you need the 1/2? As I said earlier, the work done to compress the spring--and thus the energy stored in the spring--is F_ave * x.
Your teacher is correct.
In the case of a spring, the average force is one half of the maximum force, thus: F_ave = 1/2 kx. Combining this with the earlier equation gives you the energy stored in the spring: E = F_ave*x = (1/2 k x)*x = 1/2kx^2.
where does the formula 1/2 Fx come from - i need to find out where the half comes from for some coursework of mine :S
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
