Confused about Lorentz Transformations
BWV
I thought Lorentz Transformations left Δt2-Δx2 invariant
but, for example a frame moving at .5C for Δt =1 has Δx = .5 so
Δt2-Δx2 = .75
If this is transformed by :
to a rest frame
Δt =0.65 has Δx = 0 and Δt2-Δx2≠ 0.75
not sure where I have gone wrong here, any help would be appreciated
BWV said:
I thought Lorentz Transformations left Δt2-Δx2 invariant but, for example a frame moving at .5C for Δt =1 has Δx = .5 so
Δt2-Δx2 = .75. If this is transformed by [Lorentz Transformation] to a rest frame [then] Δt =0.65 has Δx = 0 and Δt2-Δx2≠ 0.75
Not sure where I have gone wrong here, any help would be appreciated
You made a mistake with your arithmetic. If you plug your numbers into the Lorentz Transformation equation that you quoted, the result is Δt' = sqrt(0.75) and Δx' = 0, so the quantity Δt'2-Δx'2 equals 0.75, just as before.
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Abstract The gravitational-wave signal GW250114 was observed by the two LIGO detectors with a network matched-filter signal-to-noise ratio of 80. The signal was emitted by the coalescence of two black holes with near-equal masses ## m_1=33.6_{-0.8}^{+1.2} M_{⊙} ## and ## m_2=32.2_{-1. 3}^{+0.8} M_{⊙}##, and small spins ##\chi_{1,2}\leq 0.26 ## (90% credibility) and negligible eccentricity ##e⁢\leq 0.03.## Postmerger data excluding the peak region are consistent with the dominant quadrupolar...
