Solving Basic SR Confusion for Twin Paradox
In summary: The twin paradox is the apparent contradiction between the physical laws of motion and the apparent experience of motion experienced by one twin of a pair of twins who each think the other twin is moving. The paradox arises because the laws of motion describe the behavior of a single object, the twin who is presumed to be stationary, while the experience of motion describes the behavior of two objects that are in relative motion.From the very beginning you have two possible frames - the one in which the Earth twin and the distant Star are not moving and the one in which the 'traveling' twin is not moving. They can't be both inertial since two inertial frames must have a constant relative velocity. Their relative velocity changes in direction when the traveling
  • #36
Jesse - in your your post 26 you state:
" No, I just deny the implications you draw from these examples, implications which Einstein never remotely states himself, and which in order to endorse would require him to deny the basic premises of his own theory."
Well, when I use the same language as Einstein and recount the same experiment, you are of course free to say that I have misinterpreted his teachings. But I am no different that the thousands who have attempted to rationalize his "peculiar results" with the underlying foundations of SR.
Recall that Einstein, in commenting upon the peculiar results, does not attempt to explain them - nor does he suggest that we make measurments during the experiment - there is a start event where both clocks are in sync in the same frame and there is an end event where both clocks are in the same fame but "out of sync" Since I do not know how that can happen, I assume there is something different about the two frames that occurred during the experiment. We do not like the idea of a preferred frame, so we fall back upon the idea that acceleration somehow modified the characteristics of one frame or the other. If that is a Cardinal Sin, then please tell me how I can avoid hell.
Again from the same post, you state: "You get a real difference of the times on both clocks, but that doesn't tell you anything about which actually accumulated more time since the moment the clock accelerated, since different frames disagree about the initial time on the non-accelerating clock at the moment the first clock accelerated (since they disagree about simultaneity), and there is no reason to prefer the point of view of the frame where they were initially at rest over other inertial frames except your own prejudices which you never provide the slightest reasoned argument for."
Well, cannot the time on the non-accelerated clock be checked by an adjacent clock which is in sync with the clock that is located at the final destination? Maybe I am not understanding your objection. When Einstein set up the thought experiment, he didn't address this - so I sort of figured he knew what he was doing - and skipped over it myself.
So is this the bases for your criticism of my analysis or should it be directed to Einstein's sloppyness?
  • #37
But you don't use the same language, you say things like "both clocks cannot be ticking slower than the other" which Einstein never hinted at. Also, your whole argument is based on discounting the relativity of simultaneity, and saying that if two clocks are "synchronized" in their own rest frame, this means they are synchronized in some universal, frame-independent sense, so that if you accelerate one to meet the other and it shows a smaller time, we are somehow forbidden to explain this from the perspective of a frame where the clocks were not synchronized at the moment the clock was accelerated. But Einstein was clear to use "synchronous" only in a frame-dependent, relative sense:
From this there ensues the following peculiar consequence. If at the points A and B of K there are stationary clocks which, viewed in the stationary system, are synchronous; and if the clock at A is moved with the velocity v along the line AB to B, then on its arrival at B the two clocks no longer synchronize, but the clock moved from A to B lags behind the other which has remained at B by 1/2*tv^2/c^2 (up to magnitudes of fourth and higher order), t being the time occupied in the journey from A to B.
I can really think of nothing in this description that I would modify if I wanted to describe the same experiment myself--does this mean you think that I am in secret agreement with you about there being a real truth about which clock was ticking slower? If not, exactly what is there in this description that makes you think Einstein was thinking this way? How do you think a person like me, who clearly doesn't believe there is a definite truth about which clock was ticking slower after the acceleration, would describe the experiment differently?
What do you mean "explain" them? What needs explanation?
Don't know how what can happen? And what "two frames" are you talking about? No second frame was used in analyzing the experiment. Of course you could analyze it from a different frame, like the frame where clock A was at rest during the time it was closing in on clock B, but this frame would predict exactly the same thing about the times on each clock when they meet. So, for someone who accepts relativity, there is no mystery here--maybe there is a mystery to you because you are unwilling to accept the relativity of simultaneity, but stop projecting that onto people like Einstein when they give absolutely no indication of agreeing with you in their words.
No, as long as we stick to inertial frames, we don't have to say acceleration modified any frames at all. The laws of physics in the frame where clock A was at rest during the time it was moving in the "stationary frame" are exactly the same as in the stationary frame.
Einstein wasn't being "sloppy", he just didn't feel the need to analyze the same problem from the point of view of multiple frames. If you want to analyze things from the point of view of a different frame K'' where clock A was at rest after it accelerated (during the time interval when it was moving towards B at velocity v as seen in the 'stationary' frame' K), then in this frame K'' clock B was not synchronized with clock A at the moment clock A accelerated. You could indeed check this with clocks adjacent to A and B which are at rest in frame K''--if we call two clocks at rest and synchronized in this frame C and D, and if clock C was adjacent to clock A when C read 12:00 and A also read 12:00 at that moment, then if clock D was adjacent to B when D read 12:00 as well, clock B would read some significantly later time at this moment. Einstein spent the whole first section of his paper explaining how simultaneity should be defined physically in a given frame, so if you have really understood and assimilated that section this shouldn't seem strange to you.
  • #38
From Jesse's post 37: "But you don't use the same language, you say things like "both clocks cannot be ticking slower than the other" which Einstein never hinted at."
That is simply a general statement made by numeros authors (including Brian
Green) that reflects the impossibility of such a situation - I assumed you you recognize it The point is the comment is introductory to the analysis - while the clocks are in relative motion, each observer can set up an experiment that indicates that the other guys clock is running slow - that has nothing to do with Einstein's experiment that you have recited.
I will treat each of your comments in a separate post
  • #39
From Jessee's post 37. "I can really think of nothing in this description that I would modify if I wanted to describe the same experiment myself--does this mean you think that I am in secret agreement with you about there being a real truth about which clock was ticking slower? If not, exactly what is there in this description that makes you think Einstein was thinking this way? How do you think a person like me, who clearly doesn't believe there is a definite truth about which clock was ticking slower after the acceleration, would describe the experiment differently?"
Can I conclude from your statement that there is no difference between the time accumulated by the A clock and the B clock? In other words, we start with A and B separated but in sync - A moves to B, and stops. Both clocks are in the same frame as they were before the motion, but they are now together. Do they read the same?
  • #40
From Jesse's post 37: "What do you mean "explain" them? What needs explanation"
Oh, about 10,000 articles that were written between then and now If it didn't need explaining, why did Einstein take the time to write his 1918 article explaining it?
  • #41
From Jessee's post 37: "Don't know how what can happen? And what "two frames" are you talking about? No second frame was used in analyzing the experiment. Of course you could analyze it from a different frame, like the frame where clock A was at rest during the time it was closing in on clock B, but this frame would predict exactly the same thing about the times on each clock when they meet. So, for someone who accepts relativity, there is no mystery here--maybe there is a mystery to you because you are unwilling to accept the relativity of simultaneity, but stop projecting that onto people like Einstein when they give absolutely no indication of agreeing with you in their words."
The second frame is the one in which the A clock is at rest during the coasting phase - it is not mentioned because as I have said many times, the peculiar results are due to the fact that one of two separated clocks originally in sync is put into motion - once in motion, a second frame is created. When the clock put in motion is stopped, it is then in the original frame - during the experiment, B clock was one frame and A clock was in the other. Einstein predicts that the two clocks are now out of sync -
Einstein does not mention simultaneity in describing the time differences - but if you insist, there is no problem in synchronizing two clocks in the same frame initiall nor is there any problem in reading them in the same frame after the moved clock is returned - simultaneity is an issue in relatively moving frames - here both measurmentws are made while both clocks are at rest in the same frame
  • #42
Jessee --Before posting more - our whole difference turns on your answer to post 39. If you do not believe Einstein intended to predicta real substantive temporal difference (as you have asserted in one of our previous discussions- then fine - we can discuss that - if you think the moved clock accumulated less time, then tell me how that can happen if the frames are identical
  • #43
Are you claiming that numerous authors, including Brian Greene, say it is impossible that there is not a single truth about which clock is running slower? I've asked you to provide such a quote before, and you never do. Please provide one, I think we will see that, as with the Einstein quote, you are simply reading in implications that weren't intended by the author.
Of course not, what about my statement would possibly lead you to conclude I would think that? Once again you have a knack for reading implications in that are not even remotely suggested by the text you quote.
It is meaningless to talk about frames being "created", since frames are just coordinate systems, there is no need to have an object at rest in a particular frame in order to analyze a problem from that frame.
It is at rest in the original frame, but again, you are not somehow forced to use one frame or another by the motion of the objects, you can continue to analyze the situation from the frame where the A clock was at rest during the coasting phase, or you could analyze the situation from the perspective of a frame where neither A or B was at rest at any time in the entire experiment, it doesn't matter. This is analogous to the fact that you don't have to put the origin of your spatial axes at the position of one of the clock, you could have the origin be light years away from either clock. You are completely free in your choice of inertial coordinate systems to analyze any problem, they're just coordinate systems and nothing more!
He doesn't mention the different definitions of simultaneity in different frames in that particular example (although the entire opening of the paper deals with simultaneity issues), but that's because he isn't interested in analyzing the problem from different frames, he just picks the one that's most convenient. And he does specify that when he says the clocks are "synchronous" before A accelerates, this is just relative to the stationary frame K, he doesn't use "synchronous" in a frame-independent sense.
I didn't say anything about there being a problem, I just pointed out that you're wrong to claim the experiment somehow shows the A clock was ticking slower than the B clock between the acceleration and the two clocks meeting in any absolute frame-independent sense, since you could certainly analyze the problem from a different frame where A was ticking faster than B during this period (though Einstein didn't choose to do this). My point about synchronization was that in this frame A would not be synchronized with B, in fact B would be ahead of A at the moment that A accelerated, which would explain why B could still be ahead of A when they met even though B was ticking slower in this frame. This is a perfectly straightforward result in relativity, there is absolutely no reason to think Einstein would dispute it (he spent the whole first part of the paper discussing how different frames define simultaneity differently), and likewise there is nothing in Einstein's words to suggest he thinks A was ticking slower than B in any absolute sense.
  • #44
My claims are simply the straightforward claims of relativity. From relativity, you can certainly predict that the A clock will show an earlier time than the B clock when they meet--if the B clock reads 4:00, the A clock might read 3:00. But it is also clear in relativity that there is no frame-independent answer to whether A or B "accumulated more time" between the time A accelerated and the time A reached B, because different frames disagree what the time was on B at the "same time" that A accelerated, due to the relativity of simultaneity. For example, if A read 2:00 at the time it accelerated, one frame might say that this event was simultaneous with B reading 2:00, another might say it was simultaneous with B reading 3:30. In both frames A accumulated 3:00 - 2:00 = one hour between the moment of acceleration and the moment of reaching B, but in the first frame B accumulated 4:00 - 2:00 = 2 hours (more than A), while in the second frame B accumulated 4:00 - 3:30 = half an hour (less than A). There is no reason to prefer one frame's answer to another, so there is no single objective truth about who "accumulated more time", even though all frames agree that at the time they meet A reads 3:00 and B reads 4:00.
  • #45
It is true, one can analyse the two clocks A and B from different frames that are in relative motion wrt to A and B - and if you keep track of the apparent rates of clocks at all stages of the experiment, you will arrive at the same answer. But this obscures the point I have been laboring - for example, when a turn around twin changes from an outbound rf to the inbound rf, he sees the clock carried by the stay-at-home twin suddenly read more time - of course the change of direction by the turn around twin cannot affect the watch carred by the stay at home twin - it is simply a book keeping process that works to arrive at the correct age difference when the two twins reunite. The point is, there are many methods of arriving at the correct age difference, but they do not explain the age difference. That is why Einstein wrote the 1918 paper - if SR explained the results of the age difference, Albert would certainly not have felt the need to provide a constructive explanation. Following suit, others such Max Born, Dennis scima, Ron Lederman, have taken the position that SR cannot explain real time dilation. We get back once again to Rindler's comment that I have previously quoted -
This isn't just a case where there are several correct ways of working the same problem that all give the same answer. If Einstein's 1918 and Born's analysis is correct, then doing the problem in different frames that are always inertial and always identical should not work. The fact that "it does," to me, means there is a missing connection.
You wanted some quotes from authors that have said "two clocks cannot each be slower than the other" Some of my library is at my present location, much of it is elsewhere - I will try to find a couple.
  • #46
He doesn't see that, what he sees is explained on the doppler shift explanation of the twin paradox page. Presumably what you're referring to is a switch of coordinate systems before and after acceleration (or equivalently, a single non-inertial coordinate system), each time using the inertial coordinate change where the twin is at rest. But I don't think this type of coordinate switch has any deep physical meaning, any more so than the fact that if you switch between a coordinate system whose spatial origin is centered on the ship to one whose spatial origin is 1000 light years away, the ship's coordinate position will suddenly jump by 1000 light years.
Is the 1918 paper you're talking about available online? If you're just talking about the general relativity explanation of the twin paradox, I don't see how this explanation is any more "constructive" than the one in SR, it's just a different method of calculating the answer based on a non-inertial coordinate system, as opposed to SR's method of calculating the answer in an inertial system. Neither method suggests there is an "objective truth" about which clock is "accumulating time more quickly" during a given phase of the journey (the outbound leg, say), although they all agree on the time both clocks show when they reunite at a single point in spacetime (presumably you could choose many different non-inertial coordinate systems to analyze the problem and they'd disagree about the rate each clock was ticking at different times). Do you think Einstein's 1918 paper does suggest such an objective truth? If not, are we or are we not discussing your claim that there must be some objective truth about which of two clocks is accumulating time faster?
Given your strange way of interpreting quotes, I don't trust you that they take this position unless you can show me a quote. Some physicists may suggest SR is incomplete because (in non-tensor form) it doesn't have the same laws in non-inertial coordinate systems as in inertial ones, but this is different from saying that GR can "explain real time dilation" whereas SR cannot, and it definitely doesn't suggest there is an objective truth about which of two separated clocks is accumulating time faster.
Are you still talking about this quote?
"Granted that the motions of A and B are not symmetric, yet it could be maintained they are symmetric most of the time...the three asymmetric activities can be confined to arbitrarily short times...how is it then that such a large asymmetic effect can arise, and, morover, one that is proportional to the symmetric portions of motion? " The reason is that accelerations, however brief, have immediate and finite effects on A but not B."
Context would be helpful here. Which object accelerated, A or B? When he says "immediate and finite effects" is he talking about the "jumping of clocks" in some non-inertial coordinate systems which you talked about earlier, or something else?
Why shouldn't it? My understanding is that the "GR" analysis of the twin paradox just adds a new way of analyzing the problem in non-inertial coordinate systems, there's no reason it should invalidate the old way. And again, using the GR method you can presumably analyze the same physical situation using different non-inertial frames, and I'm sure they'd disagree about the rate the clocks were ticking at different moments.
  • #47
Jesse - what do you think of this:
An observer A, traveling into space in a rocketship, accelerates during a period T1 until he attains a speed v relative to the frame G of the fixed stars. He then falls freely towards some distant celestial object, where he reverses his motion during a period T2, and returns freely to Earth with the same speed as before. Finally he decelerates during a period T3 and lands. If for example v = square root of 3 times c over 2, A's clocks will have gone at half-rate compared with those of G during his free motion.
  • #48
Jesse from your post 46: "He doesn't see that, what he sees is explained on the doppler shift explanation of the twin paradox page."
Yes he does if you draw the lines of simultaneity
  • #49
Jesse - again from post 46: "Is the 1918 paper you're talking about available online? If you're just talking about the general relativity explanation of the twin paradox, I don't see how this explanation is any more "constructive" than the one in SR, it's just a different method of calculating the answer based on a non-inertial coordinate system.."
Actually, I don't think it is available for free on line, but there are several almost complete excerpts. A primary theory would be SR or the 2nd law oif thermodynamics, a constructive theory would be created by adding up all kinetic energies of the individual motions of the molecules to reach the same conclusion, or in the case of relativity, to account for the time dilations during each acceleration taking into account the distance between the two clocks
  • #50
Jesse - more on my comment in post 48 from Wikipedia see last line:
"In the spacetime diagram on the right, the first twin's lifeline coincides with the vertical axis (his position is constant in space, moving only in time). On the first leg of the trip, the second twin moves to the right (black sloped line); and on the second leg, back to the left. Blue lines show the planes of simultaneity for the traveling twin during the first leg of the journey; red lines, during the second leg. Just before turnover, the traveling twin calculates the age of the resting twin by measuring the interval along the vertical axis from the origin to the upper blue line. Just after turnover, if he recalculates, he'll measure the interval from the origin to the lower red line. In a sense, during the U-turn the plane of simultaneity jumps from blue to red and very quickly sweeps over a large segment of the lifeline of the resting twin. The resting twin has suddenly "aged" very fast, in the reckoning of the traveling twin."
  • #51
I'd say the person writing the quote is working from within G's rest frame, which is certainly the most natural frame to use when analyzing this sort of the problem, although this should have been stated more clearly.
They aren't "the" lines of simultaneity, they are just what you get if you stitch together the lines of simultaneity from two different inertial frames, as I said in my last post. But this doesn't uniquely define the "perspective" of the accelerating twin--in basic SR you're only allowed to use purely inertial frames, and once you bring in non-inertial coordinate systems you're free to use any smooth coordinate system you want, you could draw the lines of simultaneity as wavy lines and it'd be just as valid.
Can you link to some please?
I don't understand what you mean by "taking into account the distance between the two clocks". Does this notion of primary vs. constructive come from Einstein's paper? Are you claiming that Einstein says there is some objective truth about which of two distant clocks is ticking faster? If so I really don't believe that, I'd need to see some quotes where you think he suggests this.
Again, the wikipedia quote is just saying what happens if you stitch together his inertial rest frame before the acceleration and his inertial rest frame afterwards. But there isn't really any justification in SR or GR for saying this uniquely defines the "perspective" of an accelerating observer.
  • #52
Jesse from post 51: They aren't "the" lines of simultaneity, they are just what you get if you stitch together the lines of simultaneity from two different inertial frames, as I said in my last post. But this doesn't uniquely define the "perspective" of the accelerating twin--in basic SR you're only allowed to use purely inertial frames, and once you bring in non-inertial coordinate systems you're free to use any smooth coordinate system you want, you could draw the lines of simultaneity as wavy lines and it'd be just as valid.
What I was referring to was the last line of post #50 - the turn around twin perceives a big jump in the time on the clock of the stay at home twin - and as I said, that type of analysis gets the right answer, but it skirts the issue of what is taking place at all times in the frames of the two clocks.
Let us go back to post 47 - you agree with that I think. So in the last line, it states that A's clock will have gone at half rate compared to B's during the free motion. Are you also saying that if we attach a coordinte system (frame ) to B, then by B's reckoning A's clock is going at half rate during the coasting periods?
  • #53
But as I said, this is not the single correct way to define the traveling twin's "perspective", it's just one choice of non-inertial coordinate systems in which the traveling twin is at rest (one obtained by stitching together two inertial coordinate systems), you're free to pick any number of others, including ones where there is no such "jump", or where the Earth-clock ticks slowly for almost the entire trip but super-fast for the last minute before the traveling twin arrives at Earth.
What I said was that it is an accurate description of what happens in G's inertial rest frame (G was the one who moved inertially, A was the one who moved away and then turned around to rejoin G). But I also said I thought the author was being a bit sloppy by not specifying which frame was being used, even if G's frame is the most "natural" one to use in that scenario. (But I suppose the quote could also just be interpreted to mean that the total time elapsed on A's clock between the time of departing a G-clock and reuniting with it would be half the time elapsed on the G-clock, in which case we wouldn't have to worry about the perspective of different frames at all since they all agree on this).
By B do you mean G? Again, I think the quote was already speaking from the perspective of G's inertial rest frame.
  • #54
Yes - I meant G - G is the inertial frame of the Earth and fixed stars that this persons uses - we can put a clock B at rest in G and it stays put.
Now let us focus on the first part of the trip - A accelerates relative to G to velocity v, and coasts. What do you think of the last line - is the A clock running at half speed as reckoned by B during the coasting phase?
  • #55
PS - Jesse. I thought I had copied the Wikipedia article about the Einstein 1918 paper in a post - but somehow it didn't show up - anyway, it is a decent summary of the paper from the standpoint of the accelerating twin.
  • #56
Like I said, I think it's correct if it refers to how things work in G's inertial rest frame, or if it refers to the total time elapsed on A's clock between the time it departs from a clock at rest in G and the time it reunites with it. But there is no frame-independent sense in which we can say that A's clock was running at half the rate of G's during a particular phase of the trip, like the outbound leg.
What's the title of the wikipedia article?
  • #57
  • #58
Well, there may be no frame independent sense - and there are always sync issues that will be different as to the start and stop components that define a spacetime interval as viewed from relatively moving inertial frames - but the interval (the spacetime distance between the end of the acceleration and turn around point) will be the same in the G frame and the frame attached to A. From G's point of view, the B clock interval is entirely temporal, whereas from G's point of view the A clock interval is a combination of spatial and temporal components. Now, if we attach a coordinate system to A, and measure the same interval in the A frame and G frame, I think you are saying there is no difference as to what A would measure from A's frame and what G measured from G's frame since we cannot tell which frame is in motion. Ergo, there is no reason to believe the A clock will have accumulated less time when it begins its turn around
At least I think that is what you are saying. Correct me if I am wrong - actually I don't think I need to tell you that.
  • #59
yogi said:
#52...
The answer could be that the stay at home twin was in the preferred rf, so the outward-bound twin’s clock runs slow all the time it's moving. Then at turn around the moving twin’s clock would continue to run slow and there wouldn’t be a big jump in the time on the clock of the stay at home twin.
PS: SR doesn't allow for a preferred rf, but it doesn't prove it cannot exist.
  • #60
If there's no frame-independent sense in which one clock is running slower than the other, and if at any given moment there are equally valid frames where A's clock is running slower than G's and frames where G's clock is running slower than A's, then what are we debating here exactly? I was just trying to debate your statement that two clocks cannot each be running slower than the other, that there must be an actual physical truth about which was "really" running slower at a given moment.
I guess B is a clock at rest in G's frame? If so, I agree.
I don't remember saying anything remotely like that--what specific quote gave you this impression? All I've been saying is that you can come up with equally valid coordinate systems where at any given moment, or doing any particular phase of the trip (like the outbound leg), one frame says clock A was running slower and another frame says clock B was running slower. But of course all frames will agree on the total elapsed time on each clock between A and B leaving each other and A and B reuniting (specifically, they'll all agree that A shows less elapsed time), because these are physical events and all frames make the same physical predictions!
  • #61
Jesse -Then I still don't know what you are saying. When I claim that the two clocks will have accumulated different amounts of time during the one way trip, and that bringing the two clocks to rest (not together, but simply brought to rest) in the G frame, you say something else - like post 56.
Wisp - yes, I agree. It is hard to get from the notion of equivalent inertial frames to Einstein's claim in his 1905 paper of real age difference. In order for their to be a real age difference, there must be an asymmetry. The only difference between the clock frames in the one way trip is the initial acceleration - but it still leaves the physics unanswered. Rindler takes the view that the initial acceleration (In the scenereo described in post 47) produces an asymmetry because the accelerated twin has been put into a frame where he is already half way to his destination due to length contraction, and therefore the A clock he carries with him will only accumulate 1/2 as much time as the clocks in the G frame during the interval. This comports with the formulas and so the numbers come our right, but ...
  • #62
Yes, if you don't actually bring them together you can't say which clock accumulated more time. But I understood the quote about the G frame to be a standard twin-paradox-type situation where a clock moved away from another clock on Earth and then returned to it, not just came to rest relative to it at a distance from it:
An observer A, traveling into space in a rocketship, accelerates during a period T1 until he attains a speed v relative to the frame G of the fixed stars. He then falls freely towards some distant celestial object, where he reverses his motion during a period T2, and returns freely to earth with the same speed as before. Finally he decelerates during a period T3 and lands. If for example v = square root of 3 times c over 2, A's clocks will have gone at half-rate compared with those of G during his free motion.
Did you interpret this quote differently?
I don't trust your paraphrases of other people's positions--can you give the full quote where you think Rindler is saying this?
  • #63
Jesse - Special Relativity by Rindler at page 31: "How is it that a large asymmetric effect can arise, and moreover, one that is proportional to the symmetric portions of the motion? The reason is, that accelerations, however brief, have immediate and finite effects on A but not B. During the period T1, for example, A finds he has accomplished more than half the outward journey! For he has transferred himself to a frame in which the distance between the Earth and his object is halved (length contraction) and this halving is real to him in every possible sense. Thus he accomplishes his outward trip in about half the time B ascribes to it, and the same applies to his return trip."
The situation quoted in your post 62 which you quoted from my earlier post is a direct quote out of Rindler at page 30. I will convey to Wolfgang your critique of his misconceptions about special relativity
  • #64
I didn't say there were any misconceptions in the quote, just in your interpretation in it. For example, the quote you post above doesn't say what you claimed it did. In particular, it doesn't say anything about it making sense to say that one clock is accumulating time more slowly than the other in an absolute sense while they are separated. It just says that when A accelerates to a large speed relative to the Earth, then in his new inertial rest frame the distance to the object is much shorter than it was in the Earth's frame, and that this explains why in this frame (not in any universal frame-independent sense) the time for the ship to get from the Earth to the destination is half the time between these events as measured in the Earth's frame. This is essentially the exact same point I was making about the explanation for how a high speed pion makes it to the Earth's surface in the pion's own rest frame back in post #28!
  • #65
In my post 61, I stated that Rindler analysed the situation by treating the accelerated twin as being put into a frame where he is already halfway to his destination - you didn't believe that - so I copied the whole paragraph which states that A finds he is already halfway to his objective ..so he accomplishes his outward journey in about half the time B ascribed to it.
These are exactly the same thing - you challenged the correctness of my statement in your post 62 and I substantiated it - so then you go back to some other post and try to incorporate it into what is at issue - but all that is in issue in your post 62 and my post 63 is Rindler's analysis. You did not believe he said what I paraphrased and you were wrong. If you want to talk about extending or embellishing upon how the differences can be viewed or delve into or other ways of viewing the matter - fine - that is another subject. You have the math down, but you have a very limited perspective. There are many ways of arriving at the age differences - but if you were to accept Rindler's analysis, then you would have to reject Lederman's, Sciama's and Born's because they are not mutually consistent. When I hear many times over again the "rightness" of special relativity, I always wonder "which version of relativity is the right one" Sort of like going to church to get saved - but which church? One says "there ain't no hell, and the other says "the hell there ain't.
  • #66
The part I didn't believe in your paraphrase was the part in bold:
I thought you were saying the A clock would only accumulate half as much time in some objective, frame-independent sense. All Rindler is saying is that in the A frame, the time between the event of the ship leaving Earth and the event of the ship reaching its destination far away is half the time between the same two events in the G frame. But this doesn't actually mean the A clock is objectively ticking faster, because the A frame and the G frame disagree about what time on the Earth-clock is simultaneous with the time of the ship reaching its destination. If the ship left when both its clock and the Earth's clock read 2000, and when the ship arrived at its destination its own clock read 2010, then in the G frame the event of the ship reaching its destination is simultaneous with the Earth clock reading 2020 (the Earth's clock accumulated twice the time of the ship's clock in this frame), while in the A frame the event of the ship reaching its destination is simultaneous with the Earth clock reading 2005 (the Earth's clock accumulated half the time of the ship's clock in this frame). Nothing in Rindler's quote suggests he means that the ship's clock accumulated less time than the Earth's clock in any frame-independent sense, he was just talking about the time between the events of the ship leaving Earth and arriving at its destination in the A frame vs. the G frame.
So, once again, if our basic disagreement is over the question of whether there is any objective truth about which of two separated clocks is ticking faster, this Rindler quote doesn't help your case. You won't find any quotes from mainstream scientists that do, because it's an utterly clear-cut issue that there cannot be such an objective truth in relativity.
Are you referring to the part in post 62 where I referenced a Rindler quote that was apparently not the one you had intended to refer to in your response to Wisp in post 61? I'm not a mind reader, you had posted a number of different quotes by Rindler on this thread, and the most recent Rindler quote you had posted before my post 62 was in your post 47, which was about a twin paradox type situation where the twin actually returned to Earth, so I had assumed that from then on we were discussing that quote.
Your paraphrase was ambiguous, but if you did intend to suggest that Rindler was arguing for an objective frame-independent truth about whether the ship's clock or the Earth's clock was ticking faster, then I was right not to believe you, there is nothing in Rindler's quote that would suggest he meant to overturn basic concepts of relativity in that way. If you didn't mean this implication, but just meant that Rindler was saying that the time between the events of leaving Earth and arriving at the distant destination in the A frame is half the time between the same two events in the G frame, then I agree he was saying that, but since the heart of our debate is the issue of whether there is any frame-independent sense in which one separated clock is ticking faster than another, it's important that you not be ambiguous about the difference between these two statements in your paraphrases!
Once again, I don't believe you for a second. Please provide quotes from these people, and I'm sure we'll find that they all reach the same physical conclusions, and that the only differences in their analyses are coordinate-dependent ones, which all mainstream physicists agree have no ultimate physical significance.
Only because you apparently don't understand the very basic difference between coordinate-dependent statements and physical statements. There are no different "versions" of relativity that disagree on physical issues, they only analyze problems using different types of coordinate systems which give different answers about simultaneity and the relative rate that separated clocks are ticking, but no one aside from crackpots thinks there must be any "real" truth about these coordinate-dependent matters.
  • #67
Jesse - your post 66: "So, once again, our basic disagreement is over the question of whether there is any objective truth about which of two separated clocks is ticking faster"
No - our basic difference is how clocks in relativly moving equivalent inertial frames can wind up with different amounts of logged time when they are compared after being brought to rest at different locations in the same frame. You deny the reality of age differnce produced by one way travel - claiming they must be brought together as in the classic twin scenereo with the traveling twin returning to his start point. Since you don't see age difference in the one way excursion as a reality, you don't see it as a mystery.
If there is no mystery, you naturally have little patience with the thousands of persons that have pondered the problem and proposed various explanations because they were unsatisfied with the traditional views.
If you want to read the views of Born, Sciama, and Lederman, you can expand your library. Their views are based primarily upon Einstein's 1918 paper. It doesn't do any good to take the time to look up and type quotes from these sources as you have a twisted way of interpreting plain language. I do not say their views are right - I do say they are inconsistent with the analysis of other well known writers. Nor would I say Rindler's approach is satisfying, nor Wheeler's, nor have I ever intended to say as you imply that time runs different in different frames - although I would not exclude that as a possibility. Nor can I conclude that, in the future, all inertial frames will be found to be equivalent, or eliminate the possibility that the Earth's gravitational field may play a part in biasing measurements made to determine the constancy of one way light speed. In summary, before I condemn all other suggestions as crank or crackpot, I would prefer to await the outcome of experiments that prove them faulty. We all agree that SR has had many successes - but it is not interpreted consistently. That is why it is an interesting topic for discussion.
One more point - When I say I do not exclude something, I do not mean to convey it is likely - only that it should be considered a remote possibility until discredited by solid experimental evidence.
  • #68
It is very easy to demonstrate one-way age differences:
Spacestation A and B are a fixed distance away from each other. A sends two clocks at the same time to B with each a different relativistic speed. After both clocks have arrived, B can easily verify that the clock that arrived first is showing an earlier time than the other clock.
  • #69
If the first clock actually comes to rest with respect to B, then when the second clock arrives it will actually be at the same location as the first, and this becomes a standard twin paradox type situation where the two clocks depart from a common point in spacetime and reunite at a common point, with the first clock having a bent worldline between these points and the second having a straight one. If the clocks do not accelerate but just sail past B, there are perfectly valid inertial frames where the first clock actually had a smaller speed than the second, with the second clock moving away from B and B taking longer to catch up with it. In such a frame the second clock would be aging more slowly than the first and thus would show less elapsed time at all moments after the clocks depart, and there is no reason to prefer other frames over this one.
Do you deny that a basic principle of relativity is that the only facts which can be considered "physical" are the ones that are the same in all frames?
  • #70
It's true, I don't see a "reality" of age difference here. But once again, it's a basic relativity 101 concept that the only "real" physical facts are frame-independent ones! There are no mainstream physicists who would dispute this! And clearly the "age difference" between separated clocks is dependent on one's definition of simultaneity, so it cannot be a real physical fact.
None of them mainstream physicists.
Well, that's kind of evasive of you, if you have the sources handy it wouldn't take a great amount of effort for you to type out a paragraph or two that you think supports your views. At least tell me which specific books/papers and page numbers these supposed statements can be found! Judging by the Rindler quote, I expect that these will just be more examples of statements that can perfectly easily be interpreted in terms of the perspectives of specific coordinate systems, and that the authors will never say outright that the perspective of one coordinate system is more accurate or "real" than another, that you are simply "reading between the lines" to infer that they meant that because you want to imagine they thought like you do. My "twisted" way of interpreting quotes such as Rindler's is simply based on the assumption that these physicists probably were not trying to overturn relativity itself, which is what your interpretation would suggest (again, it is a well-understood foundation of relativity that only coordinate-independent facts are treated as physical, and that no coordinate system's perspective should be priveleged over any other's).
Without actually providing quotes, this isn't worth much, as you tend to interpret quotes in non-mainstream ways that support your own idiosyncratic ideas, whereas I try to interpret them in ways that don't make out the authors to be secret relativity-deniers. Are you familiar with the notion of confirmation bias?
Where did I "imply" this, and what do you mean by "time runs differently in different frames"? If you're talking about my statements to the effect that in some frames one clock is accumulating more time and in other frames a different clock is, I wasn't implying that you believed this, I was just telling you a totally obvious and unremarkable fact about how the standard theory of relativity deals with accumulated time of separated clocks. Of course physicists don't believe that any frame's perspective on matters like this represents a physical reality, any more than the fact that different coordinate systems assign the same event a different x-coordinate!
Now you're totally changing the subject. We were discussing whether different theoretical analyses of situations like the twin paradox or two clocks moving apart are somehow inconsistent with each other or support the notion that there is a real truth about which of two separated clocks has accumulated more time; the question of whether future experiments might discredit the theory of relativity is a completely different issue, one I wasn't addressing at all.
What I labeled "crackpot" was the claim that theoretical arguments based on relativity itself could somehow show that one coordinate system's perspective has more physical validity than another, or that there is a real truth about coordinate-dependent facts.
By mainstream physicists, yes it is. What you don't seem to understand is that simply using different coordinate systems to deal with the same problem (including non-inertial coordinate systems, as in the 'general relativity' analysis of the twin paradox) is not an inconsistency in interpretation as long as everyone agrees with the basic principle that the only physical facts are coordinate-independent ones, and that no coordinate system should be privileged over others; to deny this is to deny relativity itself, so I think it's safe to bet that if any mainstream physicists intended to question the validity of relativity they would have made themselves clear on this rather than writing in such a way that people would have to "read between the lines" to understand their position.
I'm going away on a trip for a while starting tomorrow, so I probably won't be able to continue this discussion until mid-June, but if you post any further thoughts I can respond then.
