Confusion about continuity question.
mathstudent79
1.The Question
The function f(x)=
x2/x if (x≠0)
0 if(x=0)
I thought this had a removable discontinuity at x=0, because the function s2/x is not defined at x=0, and the expression can be reduced to x.
The book (one of those AP prep guides with solutions) says that it is continuous everywhere, to note that x2/x if x≠0 and lim(x->0) f = 0.
Why was I wrong?
Thanks in advance.
mathstudent79 said:
1.The Question
The function f(x)=
x2/x if (x≠0)
0 if(x=0)
Why was I wrong?
Thanks in advance.
The function g(x) = x2/x does have a removable discontinuity at x=0.
The piecewise function, f(x) that you give has that discontinuity removed. f(x) is defined for all x, and is continuous for all x, even for x = 0.
SammyS
Thanks so much for your quick response.
So, just to be sure, once the discontinuity is removed, the function is continuous everywhere, is that right?
Thanks again.
mathstudent79 said:
SammyS
Thanks again.
Yes, that's right.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
