jbriggs444
Homework Helper
- 13,428
- 8,098
What reference frame are you adopting when you assert that the horizontal acceleration of ##m_2## is equal to the vertical acceleration of ##m_2##?niko_niko said:I am convinced that the solution to this problem has to be a mistake for the reason that the accelerations of the top block ##m_2## and the hanging block ##m_1## are simply inconsistent with each other. To reiterate, the solution in item (b) says that the acceleration of the top block is ##a## whereas the solution in item (d) says that the acceleration of the hanging block is ##a-A##. There is simply no conceivable way for the vertical acceleration of the hanging block to be ##a-A## if it was stated that the hanging block can only move in the vertical direction.
If you are using the accelerating frame anchored to ##M## then you would be correct. What happens if you shift to the inertial rest frame of the floor? Is the horizontal acceleration of ##m_2## unaffected by the change in reference frame?
