Confusion over 2nd law and conservation of momentum
Adding weight to a moving cart affects its momentum, but the cart's speed can change depending on how the weight is added. If the weight is introduced at zero speed relative to the ground, the cart will experience a backward acceleration as the weight accelerates forward to match the cart's speed. The interaction between the cart and the weight creates a force that accounts for this change. When removing the weight by lifting it straight up, the method of removal can influence the cart's motion, suggesting that careful handling is crucial. Understanding these dynamics clarifies the relationship between momentum conservation and acceleration in both linear and rotational motion.
steven george
Hi everybody, I apologize if something like this has been asked before but I have been unable to find an answer through searching.
If a weight is carefully added to a moving cart then the cart should slow down due to conservation of momentum. How is it that the cart has accelerated without a horizontal force?
This issue originally came up while discussing rotational motion. If a figure skater is spinning and brings his hands in he will speed up. How can he accelerate without any torque?
There must be something very basic that I am missing here, so thank you to anybody who can help with an answer.
It depends on how the weight is added. I'll guess: You add things at zero speed relative to the ground.
There is a force between cart and new weight, speeding up the weight to match the speed of the car. The new weight accelerates forwards, the remaining cart accelerates backwards..
Likes steven george
mfb said:
It depends on how the weight is added. I'll guess: You add things at zero speed relative to the ground.There is a force between cart and new weight, speeding up the weight to match the speed of the car. The new weight accelerates forwards, the remaining cart accelerates backwards..
I knew there must be a simple answer. Thanks for that. Now, what if that weight is taken off by carefully lifting it straight up?
What do you mean by "carefully"? The answer may depend on this.
Likes Nugatory
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
