Conic Section Equation Rotation Using Tan2β and x,y Coordinates
  • Thread starter astrololo
  • Tags
    Section
In summary: This looks different from the other parabola..Edit: Oh right I rotate it by pi/4, so I guess that I must do this myself right ? I just have no IDEA on how to rotate by...No, that is not necessary. You can just use the rotation formulas. No, that is not necessary. You can just use the rotation formulas.
astrololo
200
I have : (x)^2+(2xy)+y^2+2(2)^(1/2)x−2(2)^(1/2)y+4=0
Now when I use the rotation formulas I get : y'=(x'^2)/2 + 1
But I don't know if this makes sense...
tan2β=B/(A−C)
x=x'cos β - y'sin β
y=x'cos β + y'sin β
We know that β= pi/4 because B/(A−C) tends towards infinity.
So we replace pi/4 in
x=x'cos β - y'sin β
y=x'cos β + y'sin β
and put those in the long equation and simplify. Which gives us y'=((x'2)/2)+1
Does this make sense my answer
Now when I use the rotation formulas I get : y'=((x'2)/2)+1
Right. What is x'2 supposed to mean?
astrololo said:
tan2β=B/(A−C)
x=x'cos β - y'sin β
y=x'cos β + y'sin β
x=x'cos β - y'sin β
y=x'cos β + y'sin β
Oh sorry, what I meant is (x'^2)/2 + 1
This is extremely hard to read. It would be much better to write it using LaTeX, which this forum supports.
##x^2 + 2xy + y^2 + 2\sqrt{2}x - 2\sqrt{2}y + 4 = 0##
What I wrote was ##x^2 + 2xy + y^2 + 2\sqrt{2}x - 2\sqrt{2}y + 4 = 0##
We have a primer on how to use LaTeX (under INFO on the menu bar) -- https://www.physicsforums.com/help/latexhelp/
Note: Corrected by OP in a later post to ##y' = (1/2)(x')^2 + 1##
I don't think this is right. Your conic section is a circle, not a parabola.
According to wolfram I am supposed to have a parabola... I don't know what went wrong tbh
I don't know what you entered into WA, so I can't say why WA is telling you that your equation represents a parabola. The presence of the ##x^2## and ##y^2## terms, each with a coefficient of 1, says that this is a circle. The xy term indicates that there is a rotation. You can't rotate a circle to become a parabola.
Your work on finding the angle of rotation looks OK to me. Show what you did for this part:
x=x'cos β - y'sin β
y=x'cos β + y'sin β
Sorry for my late reply : http://www.wolframalpha.com/input/?i=x^2+2xy+y^2+2(2)^(1/2)x-2(2)^(1/2)y+4=0
Also there is now way this can be a circle because my exercice makes it clear that its an ellipse, hyperbola or parabola
Mark44 said:
OK - guess I was mistaken...
MARK this problem is going to make me insane. I'm pretty sure I applied everything correctly.
The equation you wrote, in the transformed coordinates, is a parabola, which agrees with what WA is showing. Is there still something you don't understand?
Ok, if what I have is correct, why does wolfram show it differently in this case : http://www.wolframalpha.com/input/?i=+y=((x^2)/2)+1
Edit: Oh right I rotate it by pi/4, so I guess that I must do this myself right ? I just have no IDEA on how to rotate by graph.
Think about it this way: instead of rotating the graph by ##\pi/4## counterclockwise, rotate the axes ##\pi/4## clockwise.
The problem isn't the rotating, the problem is how do I graph a rotated parabola ? I have no idea on how you do this becaus I've never done it. How do I even begin ? And btw I Must rotate it counter clock wise because my exercice offers me only the second quadrant. How do I find the vertex and the focus?
The centerline of the parabola lies along the line y = -x. The vertex of the parabola in (x', y') coordinates is at (0, 1). If this point is rotated by ##\pi/4## where does it go? Two other points in the (x', y') coordinates are at (1, 3/2) and (-1, 3/2). Figure out where these points rotate to. Then you have three points and the centerline in (x, y) coordinates, so you should be able to get a rough graph of the parabola.
These two other point you took them randomly ? Also, I need to determine what is the focus in this problem. How do u do that
Not randomly. I used x' values of -1, 0, and 1, and calculated the y' values.
To find the focus, see https://en.wikipedia.org/wiki/Parabola#Focal_length. You'll need to figure out where the focus is for y' = (1/2)(x')2, and then translate it up by 1 unit. Finally, rotate this point by ##\pi/4## to get the (x, y) coordinates.
Ok, but one thing which I don't understand. When I find my normal point of x',y' and when I rotate these points, is there some analytical method which gives me the rotation of these points? Or I do all of this by drawing ?
Ok I was able to find (0,3/2) for my focus and I was able to draw my parabola. Now it's the rotation which I need to figure out how to do.
You can find them by drawing them, or you can identify the points using simple trig. For example, the vertex in (x', y') coordinates is at (0, 1). If you rotate this point CCW, you get ##(-\sqrt{2}/2, \sqrt{2}/2)##, or about (-.71, .71). The other points will be a little bit harder, but keep in mind that the radial distance (distance between the point and the origin) doesn't change.
I hope that I don't bother you with my one thousand questions. First, can you tell me the analytic method ? Like some wiki page. Also, the radial distance is the distance between any point of the parabola and the origin right ?
I need to show how I obtained my data so I need the analytical method.
If there is a wiki page for it, it would be under rotation transformations.
Yes. In a rotation, the distance from the origin doesn't change.
You can use a matrix to rotate a vector, similar to what you did in post #1, but I don't know if you have learned that technique yet.
Ok, I finally understand. We did a rotation which permitted me to identify a parabola. Now I must redo a rotation but inversly. so I found these equations : x=x'cos theta - y' sin theta
Which seems to work because I obtained the correct vertex of -1/2^(1/2), 1/2^(1/2)
Ill continue and see where it leads. Thank you
Hey can you try 1,3/2 for me please ? I am not sure if I did my part correctly. I obtian -(2)^(1/2)/4 although I don't think its correct
In polar coordinates, (1, 3/2) is ##(\sqrt{13}/2, \theta)## where ##\theta = \arctan(1.5) \approx .98## (radians). If you rotate this by ##\pi/4## you get ##(\sqrt{13}/2, \theta + \pi/4)##, again in polar form. Can you work that out?
Forget it, I was able to make it work. In fact, I found an easier way. I rotate one coordinate x and I replace it in my long equation to find the y. (Using worlfram to find the y)
Ok I was finally able to draw this cursed parabola. May it go to hell. thank you again for your help! This page helped me a lot : https://en.wikipedia.org/wiki/Rotation_of_axes
ONE VERY LAST QUESTION. Is my equation in this form : y=(x^2)/2+1 in canonical form right ?
I don't know what "canonical form" means.
1. What is a conic section?
A conic section is a curve formed by intersecting a cone with a plane at various angles. The conic sections are the circle, ellipse, parabola, and hyperbola.
2. What is the equation for a rotated conic section?
The equation for a rotated conic section can be written as x = x'cos(θ) - y'sin(θ) and y = x'sin(θ) + y'cos(θ), where θ represents the angle of rotation.
3. What is the role of tan2β in the conic section rotation equation?
Tan2β is used to determine the angle of rotation (θ) for a given conic section. It is calculated using the formula tan2β = (2ab) / (a² - b²), where a and b are the length of the major and minor axes of the conic section.
4. How do you determine the x,y coordinates of a rotated conic section?
To determine the x,y coordinates of a rotated conic section, first rotate the coordinates of the original conic section using the rotation equation. Then, plug in the new values for x and y into the equation of the original conic section to get the rotated coordinates.
5. Can the conic section rotation equation be used for all types of conic sections?
Yes, the conic section rotation equation can be used for all types of conic sections. However, for a parabola, the equation simplifies to x = x'cos(θ) and y = x'sin(θ) + y'.
  • Precalculus Mathematics Homework Help
  • Classical Physics
