Conical pendulum with two charges
The discussion revolves around a conical pendulum system with two equally charged spheres spinning on a plane. The user calculated the centripetal force and derived a charge value of 32.7 μC, but the expected answer is 40 μC. Participants pointed out potential errors, including a miscalculation of the centripetal force and the assumption that the charges were equal rather than opposite. The user confirmed that the charges repel each other and the spheres are suspended from wires, indicating a need to balance the forces correctly. A suggestion was made to create a free body diagram to analyze the forces acting on one charge for better clarity.
Gabriel Maia
The sistem above is the one I'm interested in. There is two equally charged spheres spinning on a plane. The line has L=\sqrt{2} m and the spheres weight 0.6Kg. The angular speed is \omega = 2rad/s.
The radius for the circular trajectory is R=1m and so the centripetal force is F_{c}=m\omega^{2}R=2.4N.
I must find the charges q so
2.4=k\frac{q^{2}}{(2R)^{2}}, right? Where k=9*10^{9}N m^{2} C^{-2}.
I found q=32.7\mu C but the problem is said to have an answer 40\mu C.
Where have I commited a mistake if any?
Thank you.
Maybe you mistyped some numbers, but the centripetal force you calculated seems a couple of orders of magnitude off.
Secondly, you show the spheres as having the same charge, not opposite charges, so they are not going to provide a force in the right direction.
Thirdly, the diagram makes it look as though they are suspended from wires. Is that the case?
I mistyped the angular velocity. I wrote 0.2... now it's corrected. It should be 2.
They are repelling each other and yes they are suspended from wires. The component of the wire's tension pointing to the center of the circular trajectory balances the Coulomb force. This system is spinning in this configuration.
Ok, so draw yourself a free body diagram of one charge. What are the forces on it and which way do they act? What do the horizontal and vertical Fnet=ma equations tell you?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
