Connection between Tension/Torque/Inertia, & linear acceleration
1 reply · 6K views
JournaL
A block with mass m = 5.00 kg slides down a surface inclined 36.9 degrees to the horizontal. The coefficient of kinetic friction is 0.25. A string attached to the block is wrapped around a flywheel on a fixed axis at O. The flywheel has mass 25.0 kg and moment of inertia 0.500 kg m^2 with respect to the axis of rotation. The string pulls without slipping at a perpendicular distance of 0.400 m from that axis.
Calculate the Acceleration of the block.
"[URL
Figure[/URL]
So far I drew up two Free Body Diagrams, one of the block and another of the Pulley.
Torque = Inertia * Angular Acceleration
Angular Acceleration= linear accelreation/ radius
Newton's 2nd Law
So far I know that the pulley mass is not needed to find the acceleration of the block (according to my friend).
I used Newton's 2nd Law for the Tension of the block
Tension= mg( sin( theta) - Uk cos(theta ) - ma
Somehow I have to tie this with the Torque, but I don't know how. Would the levers be considered the radius?
Torque Net = Tension (r) - Uk (mg*r) , which would then equal to Inertia * linear acceleration/ Radius?
I got the answer to be 1.744 m/s^2
Is this right?
