Consequences of pressure on helix
  • Thread starter Thread starter Roger900
    Helix Pressure
The discussion centers on the force required to compress a helical compression spring under different pressure conditions. One engineer argues that the hydrostatic pressure acting uniformly on the spring does not affect the compression force, while the other suggests that the varying effective areas of the spring coils could lead to increased resistance. The outer coils experience more hydraulic fluid pressure than the inner coils, potentially requiring additional force to compress the spring. Despite this, the consensus is that the hydrostatic pressure is unlikely to impact the spring's performance significantly, as it remains below the yield point of typical spring materials. Ultimately, the engineers are encouraged to consider the implications of hydrostatic forces and effective areas in their calculations.
Roger900
Two engineers are disagreeing on the following issue.
Can anyone assist in providing a 3rd opinion?
The question relates to the force required to compress a simple helical compression spring.
Assume a compression spring is resting on a work table in absolute pressure of approximately 14.7 PSI. The spring requires 50 pounds of force to compress the spring.
Next, assume the same spring was submerged in 10,000 PSI hydraulic fluid. What would be the force required to compress the spring?
One engineer has a simple math formula to solve the problem...while another engineer has a more complex math formula to solve the problem.
Why would there be any difference? The pressure at all points of the wire spring are equal such that they cancel out and don't produce any resultant load on the spring.
Tell the engineers to look up the definition of a hydrostatic force.
Would a difference be resulting from the effective area differences for each individual coil loop?
If we look at a single helical coil of the spring, the outer diameter is obviously larger than the inner diameter. Hence, the outer diameter, or edge of the helical coil is physically in contact with more hydraulic fluid than the inner edge.
As the spring is being compressed, the diameters of each helical coil is increasing. Since the outer edge is under more "resistance" pressure to enlarge versus the inner edge desire to expand, would this not require more force be added to compress the spring - to overcome the resist forces from the differences in area?
The only difference is, there is a compressive hydrostatic stress field in the spring. But 10,000 psi is way below the yield point of most "normal" spring materials, so the stress would have no effect unless you were planning to stretch the spring close to its elastic limit.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
