Conservation/Conversion of energy
  • Thread starter Thread starter drkidd22
    Energy
A 4.5 kg mass is dropped from 3.3 m onto a spring with a spring constant of 25 N/cm, leading to discussions about energy conservation. The potential energy (PE) of the mass is calculated as 145.53 J, and the velocity just before impact is found to be 8.04 m/s. The key equation for solving the spring compression involves equating initial potential energy to the spring's potential energy at maximum compression. A quadratic equation is derived, but confusion arises over unit conversion from N/cm to N/m, which is crucial for accurate calculations. The final consensus emphasizes the importance of considering both gravitational and spring energy in the solution.
drkidd22
A mass of 4.5kg is dropped from a height of 3.3m above a spring. spring const is 25N/cm. How much is the spring compressed.
F = 4.5*9.8 = 44.1
PE = mgh = 4.5*3.3*9.8 = 145.53
v = sqrt(2(9.8)(3.3)) = 8.04m/s
The above are the few things I was able to grab out of the given information. The issue I'm having is plugging this into an equation to find the spring
Energy is conserved in this problem. If you write
initial energy = final energy
and then fill in the details of the kinds of energy involved you will be able to solve for the spring compression.
so I get that mgh = 1/2mv^2+mgh?
145.53 = .5(4.5)(8.04)^2+(4.5)(9.8)h
.7m?
I don't think I did it right
Well I looked into a few of the formulas on the book and I get to a quadratic equation, but I'm still missing something here and I'm not sure what it is.
.5(.25)Y^2-(4.5)(9.8)Y+4.5(9.8)(-3.3)
0.125Y^2-44.1Y+145.53.
356? That's not possible so any adive on this will be appreciated.
Thnsx
Got it done. My equation above is right, the only problem was that I had to convert N/cm to N/m.
Thanks
You didn't consider the spring!
Initially you have the mgh. When the mass hits the spring, it comes to a stop and you only have spring energy ½kx².
