Conservation of energy of an ice flake
The problem involves calculating the speed of a 1.90 g ice flake released from the edge of a hemispherical bowl with a radius of 28.0 cm. The conservation of energy principle is applied, equating kinetic energy and gravitational potential energy. The initial calculations yielded a velocity of 23.44, but the radius needed conversion from centimeters to meters. After correcting for units, the final speed calculated is 2.344 m/s, which is confirmed as correct. The discussion emphasizes the importance of unit consistency in physics calculations.
lauriecherie
A 1.90 g ice flake is released from the ege of a hemispherical bwon whose radius r is 28.0 cm. The flake bowl contact is frictionless. What is the speed of the flake when it reaches the bottom of the bowl.
I took KINETIC ENERGY = GRAVITATIONAL POTENTION ENERGY. since KINETIC ENERGY = .5*M*V^2, and GRAVITATIONAL POTENTIAL ENERGY = MGH, i canclled the masses and solved for V. That gave me VELOCITY = SQUARE ROOT OF (2*G*R).
I got 23.44 for my answer but after looking over my calculations I noticed that the radius is given in cm. Need I convert it to meters? If I do my answer comes out as 2.344 m/s. Is this correct now?
Nevermind. It is correct.
