Conservation of energy of an oxygen molecule
To determine the height from which an oxygen molecule must fall in a vacuum for its kinetic energy to equal the average energy at 200 K, the conservation of energy principle is applied. The average energy of an oxygen molecule is calculated using the formula Eavg = 5/2KbT, considering it is a diatomic molecule. An initial calculation yielded a height of 7855.8 m, which was incorrect due to the wrong average energy formula being used. The correct approach involves using the diatomic molecule energy formula, which resolves the issue. This highlights the importance of correctly identifying molecular characteristics in energy calculations.
jincy34
[SOLVED] conservation of energy
From what height must an oxygen molecule fall in a vacuum so that its kinetic energy at the bottom equals the average energy of an oxygen molecule at 200 K?
Eavg=3/2KbT
Epot=mgh
I used conservation of energy and set
Epot.=Eavg. and got 7855.8 m. But it is wrong.
What is the correct ans? This one seems to be right. Or my computer's not working.
I get to see the answer only after it is due. It is due thursday. when i tried this answer, the computer says it is wrong.
Eavg=3/2KbT
Oxygen molecule is a diatomic molecule. Therefore Eavg = 5/2kbT. Try this.
Thank you.
rl.bhat said:
Eavg=3/2KbT
Oy. Forgot about that altogether. Thanks from me too.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
