Conservation of Energy on an Inclined Plane with Spring
The discussion revolves around a physics problem involving the conservation of energy on an inclined plane with a spring. A block of mass 2.50 kg is projected down a 20-degree incline towards a spring with a force constant of 500 N/m. The user attempts to calculate the compression of the spring when the block momentarily comes to rest, using the equation for conservation of energy. Initial calculations led to an incorrect compression value of 0.1035 m due to a persistent calculation error. The correct compression of the spring is ultimately determined to be 0.131 m.
bcca
Hello. Can someone help me with this problem please?
An inclined plane of angle theta = 20.0 has a spring of force constant k=500 N/M fastened securely at the bottom so that the spring is parallel to the surface as shown in figure P7.63. A block of mass m = 2.50 kg is placed on the plane at a distance d = .300 m from the spring. From this position, the block is projected downward toward the spring with speed v = .750 m/s. By what distance is the spring compressed when the block momentarily comes to rest?
In short:
Angle: theta = 20.0
Force constant: k = 500 N/M
Mass: m = 2.50 kg
Distance: d = .300 m
Speed: v = .750 m/s
Compression: x = ?
The answer is .131 m. I’m supposed to use conservation of energy. I’ve tried to solve it by choosing my reference level to be at the top of the fully compressed spring, so the height of the block fallen would be d*sin(theta)+x*sin(theta). I figure K+Ug=Us and I can solve for x with a quadratic, but it doesn't work. Sorry I don’t have a diagram :/.
Attempt:
E = E’
K + Ug = Us
1/2mv2 + mgd*sin(theta) + mgx*sin(theta) = 1/2kx2
1/2kx2 – 1/2mv2 – mgd*sin(theta) – mgx*sin(theta) = 0
250x2 – 8.379x – 1.8107 = 0
(solving the quadratic) x = .1035 m
Thanks in advance!
Hi bcca, welcome to PF.
1/2mv2 + mgd*sin(theta) + mgx*sin(theta)= 1/2kx2
check this calculation.
Oh, thank you so much! That was a very persistent calculation error :). I kept subtracting them on accident.
