Conservation of Energy problem
The discussion centers on a physics problem involving the conservation of energy and momentum for two blocks, M1 and M2, on a frictionless circular path. The user derived the velocity of block M2 as it exits the circular path using energy conservation, resulting in v(21) = SQRT(2gR). They then applied momentum conservation to find the relationship between the velocities of M1 and M2, ultimately arriving at the equation V2 = M1[SQRT(2gR)]/(M1 + M2). However, there was a discrepancy noted when M1 equals M2, where the expected result is V2 = SQRT(gR). The discussion highlights the importance of correctly applying conservation laws in solving physics problems.
a9211l
If there is a frictionless circular path with radius R cut into a block of mass M1 and a block of mass M2 slides down the path, what is the velocity of mass M2 as it leaves the block?
There is no friction between M1 and the ground.
M2=mass of falling block
M1=mass of
v(21)=velocity of M2 with respect to M1
v(1)=velocity of M1 with respect to the earth
v(2)=velocity of M2 with respect to the earth
I know that this is a conservation of momentum problem, so I used the equations. E(initial)=E(final) and P(initial)=P(final)
By using conservation of energy, I found the velocity of the mass M2 with respect to M1 as it leaves the circular path. Since it falls a distance R, I set
(M2)gR=m[v(21)]^2/2
And found v(21)=SQRT(2gR)
Since the system began with no momentum and momentum must be conserved:
0=(M2)(V2)+(M1)(V1)
What I'm trying to find is V2, I know that V2=V21+V1, so substituting V1=V2-V21 into the momentum equation...
0=(M2)(V2)+(M1)(V2-V21)=(M2)(V2)+(M1)(V2-[SQRT(2gR)])
Now the final answer I got was that V2=M1[SQRT(2gR)]/(M1+M2).
But the answer hint was that if M1=M2, that V2=SQRT(gR) which wasn't what my answer would get.
just kidding, I got it.
