What is the peak velocity of the shot putter's weighted ball?
The discussion revolves around calculating the peak velocity of a shot putter's weighted ball, which initially leaves the hand at 14.0 m/s and reaches a maximum height of 6.50 m. The equations for kinetic and potential energy are applied to find the final velocity at the peak of the trajectory. While there is confusion about whether the velocity should be zero at the peak due to potential energy, it is clarified that the ball is not thrown vertically. The correct peak velocity is determined to be 10.38 m/s, resolving the initial misunderstanding. The calculations emphasize the importance of considering the type of motion involved in the shot put.
PVnRT81
A shot putter throws her shot. At the moment the 4.00 kg weight leaves her hand, it as a velocity of 14.0 m/s and is 2.00 m above the ground. The weight reaches a maximum height of 6.50 m above the ground before falling back down.
What is the magnitude of the weighted ball's velocity at the peak of its trajectory?
Ek = (0.5)(m)(v2)
Ep = (m)(g)(h)
(0.5)(m)(v2) initial + (m)(g)(h) initial = (0.5)(m)(v2) final+ (m)(g)(h) final
(0.5)( 14 m/s)2 + (2 m)(9.8 m/s2) = (0.5)(v2) + (9.8 m/s2)(6.5 m)
Vpeak = 5.19 m/s
I don't know if this is correct... isn't the velocity at the peak supposed to be zero as all the energy is potential.
Yes, but when? What type of motion are you dealing with?
Hint: you mentioned a shot put.
PVnRT81 said:
Vpeak = 5.19 m/s
Your approach is correct, but I don't see how you got that answer. Resolve for the velocity.
Note that the weight is not thrown vertically.
The peak velocity is 10.38 m/s.
That's better.
