Conservation of flow in a pump
In a simulation involving a surge tank connected to a recirculation loop, the discussion centers on whether a centrifugal pump's flow rate of 500 GPM reflects conservation of mass or volume. It is noted that for incompressible fluids like water, both concepts align since density remains constant. However, the conversation raises concerns about scenarios where density changes, such as with temperature variations in the tank. The key question is whether the pump's flow rate should be considered in terms of volume or mass when density fluctuates. The discussion highlights the complexity of flow measurements in varying conditions, particularly in relation to centrifugal versus positive displacement pumps.
natedogg1002
Hello.
I am writing a relatively simple simulation code for looking at transient temperatures in a surge tank, which reflects a real-world system. The tank is hooked up to a recirculation loop with a pump and a heat exchanger. The pump has an average flowrate of 500 GPM. Despite the temperature therefore density of the water it is pumping, the pump moves "500 GPM".
So my question is: When a centrifugal pump has a set flowrate of 500 GPM, is that equivalent to the conservation of mass or conservation of volume?
No amount of Googling seems to have brought me any conclusions, though I have come to understand that positive displacement pumps are different than centrifugal pumps when it comes to this particular topic.
For water (or any other "incompressible" fluid), the two are the same since density doesn't vary.
In a gas, this would refer only to volume flow rate.
Ok, but what if the density does change over time? For example, my tank is hooked up to a recirculating loop with a heat exchanger. As time goes by, the water temperature in the tank rises about 100°F -- corresponding to a change in density of ~2 lb/ft³.
Is the pump actually moving 500 GPM, or the mass equivalent over time?
A gallon is a unit of volume, not mass.
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
