Conservation of Mechanical Energy and Centripetal Acceleration Problem
The discussion focuses on a roller coaster problem involving conservation of mechanical energy and centripetal acceleration in a vertical loop. It is established that the difference in apparent weight at the top and bottom of the loop is 6 g's, derived from energy conservation principles. The calculations demonstrate that the apparent weight at the bottom is influenced by the speed at that point, while the weight at the top is also related to the height and radius of the loop. To show that the results are independent of the loop's size or speed, it is noted that as long as the speed exceeds the minimum required, the derived equations hold true without restrictions. The conversation also highlights the need to correct minor errors in the initial calculations for clarity.
ctpengage
Show that a roller coaster with a circular vertical loop. The difference in your apparent weight at the top of the circular loop and the bottom of the circular loop is 6 g's-that is, six times your weight. Ignore friction. Show also that as long as your speed is above the minimum needed, this answer doesn't depend on the size of the loop or how fast your go through it.
My working for the first half of the problem, the 6g's part is as follows
Radius if loop is R
Hieght from which it is released is h
The speed at bottom of the loop is determined by the conservation of mechanical energy
1/2 mvbottom2=2mgh
Apparent weight at the bottom of the loop is obtained by the below:
mvBot2= FNorm. Bot.-mg
Therefore apparent weight at bottom is
FNorm. Bot.=mvbot2/R+mg
FNorm. Bot.=2mgh/R+mg (using result obtained via conservation of energy)
To find speed at top of the loop we have from Conservation of Energy
1/2 mvtop2+mg(2R)=mgh
mvtop2=2mg(h-2R)
Therefore using the above the apparent weight at the top of the loop is
mvTop2/R = FNorm. Top.+mg
Therefore Apparent weight is :
FNorm. Top. = (2mg(h-2R))/R - mg
Hence
FNorm. Bot. - FNorm. Top. =
2mgh/R + mg - [((2mg(h-2R))/R - mg)]=
2mgh/R + mg - 2mgh/R + 4mg + mg=
6mg
That's how i proved the first section. Can anyone please tell me how to complete the problem, namely proving that as long as your speed is above the minimum needed, the answer doesn't depend on the size of the loop or how fast your go through it. This part of the problem is relaly bugging me and I've tried heaps of ways but can't come up with a definitive, good answer
the minimum speed needed is solved by mg = mv2 / R
Therefore the minimum speed in this instance is the square root of (gr)
But i can't find a way to tie this into the problem and prove the last part
please clarify here :D:D:D
help guyz please. desperate
It looks like you already solved it. You arrived at your final equation without any restrictions on R or V (other than the speed must be sufficient to make it around the loop.)
Incidentally there are a few errors which I assume are typos in what you wrote, starting with your first equation. You should go back over your work.
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
