Conservation of momentum and energy
The discussion focuses on a physics problem involving a pendulum and a block on a frictionless surface, emphasizing the conservation of momentum and energy principles. Participants analyze the elastic collision between the pendulum bob and the block, trying to determine the mass of the block based on given angles and initial conditions. Key equations for kinetic and potential energy are discussed, along with the need to calculate the bob's velocity at the lowest point of its swing. Confusion arises regarding the correct application of energy and momentum equations, prompting clarifications on how to approach the problem. The conversation highlights the importance of careful algebraic manipulation and understanding the relationship between potential and kinetic energy in solving the problem.
royguitarboy
A pendulum consists of a 0.5 kg bob attached to a string of length 1.6 m. A block of mass m rests on a horizontal frictionless surface. The pendulum is released from rest at an angle of 53° with the vertical and the bob collides elastically with the block. Following the collision, the maximum angle of the pendulum with the vertical is 5.73°. Determine the two possible values of the mass m.
I got 2.16 kg for one...which isn't right.
Hi, you must show how you got that result, so we can fix it if it's wrong.
Ki(objec1t)+Ki(object2)+Ui(object1)+Ui(object2)=Kf(object1)+Kf(object2)+Uf(object1)+Uf(object2)
K= kinetic energy------U= potential energy-------i=initial------f=final
K=1/2mv^2-----------U=mgh
0+0+0+cos(53)*1.6*.5*9.8=sin(5.73)(1.6)+(.5)(cos(5.73)*1.6)+m2vf^2
Change in kinetic energy = 0 so,
(m1v1i^2+m2vi^2)+(m1v1f^2+m2v2f^2)=0 algebra...
m1(v1f^2-v1i^2)=m2(v2i^2-v2f^2) where m2=3.76/v^2 from the conversation of momentum part
then substituted
v^2=.8/3.76
0+0+0+cos(53)*1.6*.5*9.8=sin(5.73)(1.6)+(.5)(cos(5 .73)*1.6)+m2vf^2
OK, the LHS is the potential energy at the start. That should be sin(53) ( easy to remember because as the angle increases so does the pot.)
On the right we should have the final potential energy of the bob plus the kinetic E of the mass.
sin(5.73)*1.6*.5*9.8 + m2v2f^2
To get the momentum equation, work out the velocity of the bob at the lowest point, and you've got it ( after a bit of algebra)
Sorry I'm a little confused. I'm not sure how to get the velocity at the lowest point other than it being sin(0)*1.6 which would be 0. And doesn't " sin(5.73)*1.6*.5*9.8 + m2v2f^2" go into the momentum equation?
If it's easier to talk on aim, my sn is:
Royguitarboy246
Edit: Wouldn't that be cos(0)*1.6 which would then equal 1.6?
You get the velocity at the lowest point by equating the initial pot energy of the bob with its KE at the lowest point.
sin(57)*1.6*0.5*9.8 = 0.5*0.5*vf^2
You can get the velocity of the bob after the collision using the same approach.
No, that's energy ! The momentum equation is
0.5*( vi-vf) = m*v2 ( v2 is the speed of the mass after the collision, vi, vf are bob speeds before and after.)
I have to go now. You can do it. Use a pencil, paper and eraser, and list your quantities carefully.
