Conservation of Momentum (Elastic Collision)
In an elastic collision involving two particles of equal mass, one initially stationary, the conservation of momentum and kinetic energy equations are applied to determine the final directions of the particles. The horizontal and vertical components of momentum lead to two equations, while energy conservation provides a third equation. The discussion highlights the challenge of having too many variables relative to the equations available. A suggestion is made to draw a vector diagram to visualize the relationships and simplify solving for the angles of deflection. Establishing boundaries for the angles can help in finding a solution to show that the particles travel in perpendicular directions post-collision.
tanzl
A particle with mass m and speed v collides with another particle with
mass m, which is initially stationary. The collision is elastic. Show that
the particles travel in perpendicular directions after the collision.
1)initial momentum = final momentum
2)initial kinetic energy = final kinetic energy
Assume that B is the moving particle and A is the stationary particle.
By conservation of momentum,
For the horizontal component of the motion
mvi=mvfcos\theta+mufcos\phi
For the vertical component of the motion
0=mvfsin\theta+mufsin\phi
where
vi = initial velocity of B
vf = final velocity of B
uf = final velocity of B
\theta = angle between vector A and horizontal axis
\phi = angle between vector B and horizontal axis
By conservation of energy,
\frac{1}{2}mvi2=\frac{1}{2}m(vf2+uf2)
So, vi2=vf2+uf2
These are all the equations (3 equations 5 variables) I can get,
But it seems that I have too many variable so I can't solve for \theta and \phi. Is there any more assumption I need to make in order to solve the question?
where
So, vi2=vf2+uf2
Looks like a good start. You look armed and dangerous.
In these sorts of problems I find it useful to draw of diagram of the vectors. You know that the sum of all the x- and y-velocity vectors before and after the collison are equal which gives you the following options:
y-velocity:
uf*sin(phi) = - vf*sin(theta) Equation (1)
[equal and opposite final velocities of the two particles in the y-direction]
a) phi = 0, theta = 180 (in degrees)
b) phi = 180, theta = 0
c) 0 <= phi <= 90, -90 <= theta <= 0
d) 0 <= theta <= 90, -90 <= phi <= 0
From conservation of kinetic energy, you can eliminate options a) and b) for these particles of mass 'm'. You can then choose either c) or d) without loss of generality.
You then need to sub in Equation (1) to the equations you have for conservation of x-momentum and conservation of kinetic energy. It will require some funky algebra to solve the equation, but the trick is to place certain boundaries on what the final angles can be.
Hope this helps
Thank you for your help.
