Conservation of momentum/energy
  • Thread starter Thread starter henry3369
    Conservation
Conservation of momentum can be applied in this scenario, yielding a final angular velocity of 1.2 rev/s, while conservation of energy results in a lower final velocity of 0.69 rev/s. The discrepancy arises because energy conservation does not account for the work done by the skater in pulling their arms in, which increases kinetic energy. Non-conservative forces, like friction, can affect momentum conservation, indicating that external forces can alter the system's dynamics. Therefore, in this case, momentum conservation is the appropriate principle to use. Understanding the distinction between these conservation laws is crucial for solving similar physics problems effectively.
henry3369
http://imgur.com/cEqXb24
Ki = Kf
Li = Lf
So I tried to solve this using conservation of energy as well as conservation of momentum, but only conservation of momentum gave the correct answer. Why can't conservation of energy be used in this situation?
Here is the work:
Both of these moments of inertia already include the body:
Iinitial = 2.83
Ifinal = 0.9625
ωinitial = 0.40 rev/s
Using conservation of momentum:
Iinitialωinitial = Ifinalωfinal
(2.83)(0.4) = (0.9625)ωfinal
ωfinal = 1.2 rev/s
Using conservation of energy:
Wnon-conservative forces = 0 and no potential energy.
Kinitial = Kfinal
(1/2)Iinitialωinitial2 = (1/2)Ifinalωfinal2
(2.83)(0.402) = (0.9625)(ωfinal2)
ωfinal = 0.69 rev/s
Also, if there were a non conservative force such as friction, momentum would not be conserved because it would be an external force.
The skater has to do work to bring the arms closer to the body, and this increases the kinetic energy.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
