Final Speed of Trolley After Child Jumps Out
  • Thread starter Thread starter ritwik06
    Final Speed
The discussion focuses on calculating the final speed of a trolley after a child jumps out, using conservation of momentum. The initial scenario involves a 200 kg trolley moving at 10 m/s, with a 20 kg child running at 4 m/s opposite to the trolley's direction. Two methods yield different results: one suggests the trolley's speed becomes 10.4 m/s, while the other calculates it as 10.36 m/s. The confusion arises from the child's speed being relative to the trolley rather than the center of mass. Ultimately, the correct approach emphasizes that the child's speed must be considered in relation to the trolley's final speed, not the center of mass.
ritwik06
A trolley of mass 200 kg moves with velocity of 10 m/s on a friction less track. A child of mass 20 kg runs on the trolley with a sped of 4 m/s relative to the trolley in the direction opposite to the trolley's motion and jumps out of the trolley. What is the final speed of the trolley?
La of conservation of momentum
My reference frame is moving with the velocity of the center of mass.
4*20=200*v
v=0.4
Therefore with respect to ground velocity of trolley=10.4 m/sec?
Is my answer correct?
The confusion arises when I do it from the ground frame.
220*10=20(v-4)+ 200*v
solving to get v=10.36 m/s
Which of the two solutions is correct?
4*20=200*v
v=0.4
Careful. The speed of the child with respect to the trolley is 4m/s, not with respect to the center of mass.
Much better.
Much better.
But I thought the first one was correct. The reason being that the velocity of the center of mass and the initial velocity of the trolley was same.
Please have a look at the attached image. Its a page from a Physics Book written by Resnick Halliday & Walker. I have highlighted the points of doubt. The thing is that the calculations have been made in a similar fashion as my first method. Have a look.
I am totally confused.
That's true, but note that the child's speed is given with respect to the trolley's final speed not the speed of the center of mass.
With the rocket equation things are different. With child and trolley we are dealing with finite (sizeable) changes in mass and speed, not just just tiny continuous deltas. Note that whether you measure the speed of the ejected fuel with respect to v or v + \Delta v doesn't really matter, since the \Delta m \Delta v term would be dropped anyway.
