Conservation of Rotational Momentum and changes in Rotational Speed
The discussion revolves around a physics problem involving the conservation of rotational momentum when a blob of putty sticks to a spinning record. Given the mass of the blob and the record, along with their respective rotational inertia and initial speed, the new rotational inertia is calculated to be 0.0009 kg*m^2. By applying the conservation of angular momentum, the final rotational speed after the collision is determined to be 2.5 rad/s. Participants confirm the calculations and emphasize the importance of including units in the final answer. The solution effectively demonstrates the principles of rotational dynamics.
physicsflunky
There is a record spinning when a blob of putty falls vertically on its edge; which is .10m from the center. What is the rotational speed of the record after the blob sticks on it?
additional information:
mass of blob = .040kg
mass of record = .10kg
rotational inertia of record before collision = .0005kg*m^2
rotational speed before collision = 4.5 rad/s
I = m(r^2)
Iwi = Iwf
I = Rotational Inertia
wi = Initial Rotational Velocity
wf = Final Rotational Velocity
r = distance from point of rotation to point of applied force
(calculate new rotational inertia)
I = m(r^2)
= .040(.10^2) = .0004
.0004 + .0005 = .0009
(set initial momentum equal to final momentum and solve for Wf)
4.5(.0005) = I(Wf)
.00225 = .0009(Wf)
2.5 = Wf
What you did looks fine. Don't forget the units on your final answer.
It was correct. I'll make sure to include units in the future. Thanks.
