Conserved kinetic energy in collisions in different frames
In the discussion, participants explore how to demonstrate that kinetic energy conservation in one inertial frame implies conservation in all inertial frames for non-relativistic collisions. The conversation suggests starting with the conservation of momentum equation from a stationary frame and modifying it for a moving frame, leading to a simplified algebraic form. By expanding the terms and observing cancellations, the conservation of momentum can be established in the new frame. The next step involves substituting the modified velocities into the energy equation to show conservation of kinetic energy. This methodical approach highlights the interconnectedness of momentum and energy conservation across different frames.
bon
How do you show that in the non-relativistic case, if KE is conserved in a collision as viewed in one frame, then it is conserved in all other frames moving with constant velocity?
Not sure what to do...
thanks
thanks
Perhaps start by stating the equation for (non-relativistic) conservation of momentum as observed from a stationary frame. Then modify that equation such that it represents conservation of momentum from the perspective of a (non-relativistic) moving frame.
Then a little algebra will show you to the light. :cool:
Hmm so m1(u1' + Vcm) + m2(u2' + Vcm) = m1(v1' + Vcm) + m2(v2' + Vcm)
How does this help?
thanks
Hello bon,
How does this help?
thanks
That's a great start! :approve:
Now is where the simple algebra fits in. Multiply m1 and m2 through their factors, and you should see what I mean.
[Edit: What I mean by that is expand the terms on both sides of the equation. See what cancels out.]
Ok cool so i see m1u1'+m2u2' = m1v1'+m2v2'
i.e. consv of momentum in new frame...Now need to get consv. of energy..
should i subsstitute u1'+Vcm into energy equn and expand?
edit: yes that works!
